1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM crashing
To: Kevin Anderson <[email protected]>
Date: Fri, 19 Feb 2010 11:58:27 +0100
Hi Kevin,
Kevin Anderson wrote:
> What version of EDM are you using?  Also, what versions of Ubuntu and Gentoo are you using?
edm version is edm-1-12-27.tgz, EPICS base 3.14.10. Gentoo is up to date
with emerge --world. Ubuntu is Ubuntu 9.10.
> Did you try recompiling EDM on your x86_64 machine, or were you just using the version you compiled for x86?
I was recompiling the EPICS + edm on x86_64 machine.
I don't have the access to the x86_64 machine currently and won't have
it until March.
Others suggested to build EPICS_HOST_ARCH=linux-x86_64-debug to provide
more information and I plan to do so as soon as I get access to that
x86_64 machine again.
Thanks.
Best regards,
Hinko
> -Kevin
>> Hi all,
>> I've created few EDM screens for our IOC. Screens include a X-Y graph
>> with 1 - 8 traces.
>> Running EDM on Linux OS x86 (Ubuntu, Gentoo) works, but on x86_64 the
>> EDM process crashes as soon as the screen is executed. It looks like
>> memory management problem. Here is more information:
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
Re: EDM crashing Hinko Kocevar
RE: EDM crashing Kevin Anderson
Prev: RE: EDM crashing Kevin Anderson
Next: CAJ bug? Carcassi, Gabriele
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: EDM crashing Hinko Kocevar
