1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CA beacon errors
To: [email protected]
Cc: Yves Lussignol <[email protected]>
Date: Thu, 18 Feb 2010 09:33:19 +0100
Since last friday we get the following message on all our VME IOCs:
../online_notify.c: CA beacon routing (connect to "132.166.255.255:5065") error was "S_errno_EHOSTUNREACH"
Probably some new device on the network is replying with a "Connection refused" message to our broadcasts and we have to find it.
As a workaround, we have added a CA address list to our VMEs. The following example declares two Linux PCs:
putenv "EPICS_CA_AUTO_ADDR_LIST=NO"
putenv "EPICS_CA_ADDR_LIST=132.166.31.146 132.166.29.139"
This works fine when the caRepeater is running on the two PCs. If we stop the caRepeater on one machine, then we get the CA beacon error message on the VME for the two machines.
We use wireshark to see what happens on the network, and in fact after the first connect error in online_notify.c the following calls to connect don't send any frame and return error, even if we restart the caRepeater on the PC.
We are using EPICS 3.14.11 and VxWorks 6.7.
Best regards,
-- Pierre MATTEI & Yves LUSSIGNOL CEA Saclay DSM/IRFU/SIS [email protected] [email protected]
Prev: [Fwd: [Nexus] NeXus workshop] Pete Jemian
Next: RE: EDM crashing Kevin Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: CAJ bug? Carcassi, Gabriele
