1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Accessing EPICS PV from Allen-Bradley PLC
To: Elliott Wolin <[email protected]>
Date: Tue, 09 Feb 2010 17:51:30 -0500
For a small and short-lived test setup my A-B ControlLogix PLC needs to read some EPICS values from another system. What are my options?
How about using an Ethernet/IP server library? I.e. write a program that uses EZCA to poll the EPICS values periodically, then serve them to the PLC via Ethernet/IP...does this work?
For your "small and short-lived test setup", set up your own IOC with ao records, DOL the "real" PV from the real IOC, OMSL closed-loop, OUT to a tag on your PLC, with DTYP etherIP (http://ics-web.sns.ornl.gov/kasemir/etherip/index.html).
Steven Hartman
[email protected] || 865-466-6473
Accessing EPICS PV from Allen-Bradley PLC Elliott Wolin
RE: Accessing EPICS PV from Allen-Bradley PLC Mark Rivers
Re: Accessing EPICS PV from Allen-Bradley PLC Elliott Wolin
Prev: Re: Accessing EPICS PV from Allen-Bradley PLC Mohan Ramanathan
Next: RE: epics build with cmake Davidsaver, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Intel C Compiler icc on linux? Carl Lionberger
