On Monday 08 February 2010 17:02:27 Benjamin Franksen wrote:
> On Montag, 8. Februar 2010, J. Lewis Muir wrote:
> > In particular, I would like it if:
> > 1. there was a way to build EPICS without installing it; and if there
> > already is, make it the default. Right now, running "gnumake"
> > builds and installs. To me it should just build. I should run
> > "gnumake install" if I want to install it.
> +1
I agree, but unfortunately it's not easy to do this. The problem is that Base
builds many programs which later runs when building other parts of itself,
such as dbToRecordtypeH. Installing those programs immediately makes them
easier to run, as it allows us to use the same make rules for both internal
and external builds. As well as the executable paths, we use shared libraries
for most architectures by default; if those library files were not in their
installed location when needed by an executable, we would have to set
LD_LIBRARY_PATH when building Base but *not* when building external
applications after Base has been installed.
I have been working to try and rewrite some programs as Perl scripts which
don't need installing, but I can't fine any replacements for flex (lex) and
antelope (yacc) written in Perl that will generate C code. The output from
those programs is compiled and run on the target so the C output is essential,
and rewriting them myself seems a rather daunting and wasteful task.
We could split Base into several pieces which you would then have to build and
install in order, but I don't really think this would be a better solution in
practice.
You can currently do this:
make
make INSTALL_LOCATION=/path/to/install
The second make results in some recompilation, but it doesn't re-do everything
AFAICT. Of course you must ensure that you haven't set the INSTALL_LOCATION
variable in your CONFIG_SITE file, and this doesn't help if your aim is to run
the install step on a different machine with no compilers, but the result is
that all the necessary files get installed.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- RE: epics build with cmake Davidsaver, Michael
- epics on launchpad! Davidsaver, Michael
- Re: epics build with cmake J. Lewis Muir
- Re: epics build with cmake Benjamin Franksen
Re: epics build with cmake Bruce Hill
Accessing EPICS PV from Allen-Bradley PLC Elliott Wolin
<2010>
<2010>
