> That sounds good. If you used ImageJ as an EPICS CA clients, then one
> can have mutiple real-time ImageJ clients distributed among different PCs at the
> same time, right ?
Yes, that's correct, we do that quite a bit.
Sent: Thu 1/28/2010 10:17 PM
To: Mark Rivers
Cc: Bruce Hill; [email protected]
Subject: Re: edm : TwoDProfileMonitorClass : cropping/resizing image
Mark Rivers wrote:
> Hi Kate,
>> Do you use ImageJ for real-time image display instead of edm :
>> TwoDProfileMonitorClass ?
> Yes, I use ImageJ for real-time image display. I also have an IDL routine to do it. I have never used the edm widget, since we don't use EDM (and we want to run clients on Windows as well as Linux, etc.). ImageJ has a "Dynamic line profile" plugin that can be used to do real-time line profiles in any orientation. It can also be used to capture the image stream to an ImageJ "stack", and then that stack can be saved as a movie in AVI and other formats.
>> What I need is to use the format 7 (scalable image) of any IIDC cameras
>> and crop out a ROI for DAQ during the "real-time display" of the image. so far,
>> I only used ImageJ for offline data display (e.g. reading image data from a
>> FITS file instead of DAQ from a camera).
> areaDetector supports IICD cameras in format 7. I wrote the Windows IIDC driver and it is very complete. The Linux IIDC driver was written at Diamond, and I don't know how complete the Format 7 support is at this point. You can chose to read only an ROI from the camera, or you can read the whole chip and then use the ROI plugin to select one or more ROIs for analysis and display.
> EPICS CA clients (e.g. ImageJ) gets the data from another areaDetector plugin, and that plugin can be switched to get its data directly from the detector, or from any of the ROIs in the ROI plugin. Such switching can be done in real-time, and the ImageJ client changes its size, data type, and color mode dynamically with the data stream.
can have
same time, right ?
Kate
> This software is running on X-26A, X-17B2, and X17-B3 at NSLS, as well as other beamlines there I think.
> Mark
> ________________________________
> From: Kate Feng [mailto:[email protected]]
> Sent: Thu 1/28/2010 4:50 PM
> To: Mark Rivers
> Hi Mark,
> Mark Rivers wrote:
>> Here are a couple of ideas:
>> - I've got an ImageJ plugin that displays EPICS waveform images from the areaDetector module. It is quite flexible for zooming, line profiles, etc. It uses the native Java implementation of CA.
>> - If your cameras are supported by areaDetector, then it comes with a very flexible region-of-interest plugin that lets you select regions of the image, reverse axes, bin, etc. The ImageJ viewer responds immediately to such changes in the selected area of the image.
> and crop
> I only
> FITS file
> Regards,
> Kate
>> Mark
>> From: [email protected] on behalf of Bruce Hill
>> Sent: Thu 1/28/2010 7:36 PM
>> To: Kate Feng
>> Cc: [email protected]
>> We've had similar requests here at SLAC. We use TwoDProfileMonitorClass
>> with EDM for our cameras, and are looking for an easier way to select
>> the region of interest. We looked briefly into doing a Python/QT camera
>> viewer with this feature, but haven't had time to get serious about it.
>> If anyone has a solution for this, we'd be interested in hearing about it.
>> - Bruce
>> Kate Feng wrote:
>>> I am using the edm/TwoDProfileMonitorClass for a real-time
>>> image display. Has anyone implemented a point-and-click resizing
>>> tool via the mouse for that class so that one can interactively crop
>>> out a section of the real-time image ?
>>> A simpler implementation would be to have an active cursor
>>> being moved around the real-time image and have a text
>>> message to display the current (x,y) pixel location of the cursor
>>> for users to use it as a reference or an activation point
>>> to define the location of the cropping. Is this already
>>> implemented in the edm video widget ? Please advise.
>>> Regards,
>>> Kate
>> Bruce Hill
>> Member Technical Staff
>> SLAC National Accelerator Lab
>> 2575 Sand Hill Road M/S 94
>> Menlo Park, CA 94025
- edm : TwoDProfileMonitorClass : cropping/resizing image Kate Feng
- Re: edm : TwoDProfileMonitorClass : cropping/resizing image Bruce Hill
- RE: edm : TwoDProfileMonitorClass : cropping/resizing image Mark Rivers
- Re: edm : TwoDProfileMonitorClass : cropping/resizing image Kate Feng
Image processing plugin for areaDetector James.OHea
<2010>
<2010>
