1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: info about VI to get waveform
From: "Pawel Kowalski - BiRa Systems Inc." <[email protected]>
To: "'Clelia Scudellaro'" <[email protected]>, <[email protected]>
Date: Fri, 22 Jan 2010 11:34:58 -0700
Hello Clelia,
I haven’t done much work with the SNS module so I’m sorry I can’t give much advice there. However, it should be worth noting that as of LabVIEW 2009 the ability to bind process variables to shared variables is built right in. If you don’t have LabView 2009 you can also download an EPICS client for LabVIEW 8.6 here:
http://zone.ni.com/devzone/cda/tut/p/id/7987
I am not aware if it directly supports waveform data. I do know that it supports arrays as the record type and as far as I know that’s what waveform data is. Since this is also officially supported by NI they should be able to offer you help if you have issues with a particular record type, their big physics group has been and continues to be very involved in this development . If you look at the big-physics group under NI I know that Thierry and Arun have been part of that development and they might be able to answer your questions in more detail if nobody jumps in here first:
http://decibel.ni.com/content/groups/big-physics?view=members
Pawel Kowalski
BiRa Systems Inc.
www.bira.com
Phone:                   505-881-8887
Fax:                       505-888-0651
Address:                2410 Midtown PL NE
STE A
Albuquerque NM 87107 USA
From: [email protected] [mailto:[email protected]] On Behalf Of Clelia Scudellaro
Sent: Friday, January 22, 2010 3:48 AM
To: [email protected]
Subject: info about VI to get waveform
Hi everyone,
I'm Clelia Scudellaro, I work in Italy at the LNL for Mr Mauro Giacchini. My activity is to create a user interface using LabVIEW as an EPICS client. To do this I use the "sns template", that is the library that implements the basic functions of Channel Access library, sinchronize and monitor methods of PV reading/writing, for example: CAInit.vi, CASyncGetShort.vi, ecc. I have a problem: I need to acquire a waveform data and I can't find the right VI to get it, does it exist? If yes, can somebody tell me what is it its name? And where I can find it?
Thank you very much for the kindness.
Clelia
info about VI to get waveform Clelia Scudellaro
Prev: Re: caSnooper output Andrew Johnson
Next: RE: caSnooper output Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: info about VI to get waveform Clelia Scudellaro
Next: caSnooper output Caizhen Liu
