On Wednesday 20 January 2010 13:27:47 [email protected] wrote:
> I just tried it on a VME5100 (instead of VME2700) in a test crate and it
> was picked up fine using the same Ipac. So now it's at least isolated to
> this IOC hardware and additional software. What's still weird is that
> doing m(0xfbff0000,2) on the problem IOC shows all memory set to ffff.
> vxwrks@iocfel7 -> m(0xfbff0000,2)
> fbff0000: ffff-
> fbff0002: ffff-
> fbff0004: ffff-
> fbff0006: ffff-
> fbff0008: ffff-
> fbff000a: ffff-
With some BSPs as delivered by Wind River a bus error from a VME read cycle
can give all ones data just like that, without raising any kind of exception.
You should find that you get the same result in any of the VME Master window
address ranges. With these BSPs using vxMemProbe() is the only way to tell
whether something is responding at a particular address.
I have had to make changes to most of the PowerPC BSPs used at APS so that a
bus error will cause an exception like we're used to from 68K family CPUs,
although with the write FIFOs found in modern CPUs and bus bridges it is
usually impossible to reliably work out which instruction caused a bus error
on write (reads work OK though).
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Ipac with VIPC616 wmoore
- Re: Ipac with VIPC616 Andrew Johnson
- Re: Ipac with VIPC616 wmoore
Re: Ipac with VIPC616 Wesley Moore
Any recommendations for a Control Systems Engineer for the W.M. Keck Observatory? Kevin Tsubota
<2010>
<2010>
