1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Ipac with VIPC616
To: "Andrew Johnson" <[email protected]>
Cc: [email protected]
Date: Wed, 20 Jan 2010 14:27:47 -0500 (EST)
> On Wednesday 20 January 2010 11:50:24 [email protected] wrote:
>> I've tried a different VIPC616 and Octal-232 to no avail.
> What about the VME CPU, or the VME chassis (some VME backplanes have
> jumpers
> in them too, although their settings aren't likely to cause your
> symptoms).
> Do you have access to another working system with the same hardware in
> that
> you could try booting with this exact same st.cmd file?
> - Andrew
> The best FOSS code is written to be read by other humans -- Harald Welte
I just tried it on a VME5100 (instead of VME2700) in a test crate and it
was picked up fine using the same Ipac.  So now it's at least isolated to
this IOC hardware and additional software.  What's still weird is that
doing m(0xfbff0000,2) on the problem IOC shows all memory set to ffff.
vxwrks@iocfel7 -> m(0xfbff0000,2)
fbff0000:  ffff-
fbff0002:  ffff-
fbff0004:  ffff-
fbff0006:  ffff-
fbff0008:  ffff-
fbff000a:  ffff-
Wesley
Re: Ipac with VIPC616 Sue Witherspoon
Re: Ipac with VIPC616 Andrew Johnson
Ipac with VIPC616 wmoore
Re: Ipac with VIPC616 wmoore
Prev: Re: Ipac with VIPC616 Andrew Johnson
Next: Re: Ipac with VIPC616 Sue Witherspoon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
