1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: CAJ or PV gateway problem?
To: "Dirk Zimoch" <[email protected]>
Cc: [email protected]
Date: Tue, 5 Jan 2010 12:57:58 -0600
It would be nice if CAJ could use the environment variables, in addition
to the jca.properties file and command line definitions.
But the more serious problem is that I've been told it is (was?)
difficult in Java to discover the broadcast address of all network
interfaces, so it does not use those as the default, it uses
255.255.255.255 instead.
-----Original Message-----
Sent: Tuesday, January 05, 2010 8:08 AM
To: Mark Rivers
Subject: Re: CAJ or PV gateway problem?
Mark Rivers wrote:
> Folks,
> We found a problem with CAJ and the PV gateway yesterday.  The problem
is that CAJ "out of the box" (e.g. without changing any of the default
properties) will connect fine to PVs on the local subnet if they are
contained in a VME IOC or soft IOC.  But CAJ will not connect to PVs
that are present in a PV gateway on the local subnet.
> We've figured out the problem, and it is easy to reproduce even with
traditional CA from EPICS base.  The problem is that CAJ defaults to a
broadcast address of 255.255.255.255 when searching for PVs.  VME IOCs
and soft IOCs respond to such a broadcast, but the PV gateway does not.
Hi Mark,
The EPICS default, according to the CA Reference Manual, is to use the
broadcast addresses of all network interfaces. (If this makes sense or
not is another issue -- imagine an IOC and a CA client on the same
computer with two network interfaces => duplicate channels.)
This behavior can be modified with the environment variables
EPICS_CA_ADDR_LIST and EPICS_CA_AUTO_ADDR_LIST.
The CA gateway parses its command line parameters for server and client
address and modifies the environment variables before starting the CA
server part. Normally, one specifies the broadcast address of one
network card as the server address. Thus, I would say the gateway is
working correctly.
If CAJ uses an other default and/or does not look at the environment
variables, CAJ does not conform to the CA Reference Manual. I dare to
say it is buggy. (And don't tell me "Java cannot read the environment"
-- all Java fans say "Java can everything" :-P )
I wonder why you get any reply at all using 255.255.255.255? Is there
any "magic" in the IOC server that allows IOCs to respond to
255.255.255.255 and that is not included in the portable CA server?
Dirk
Re: CAJ or PV gateway problem? Dirk Zimoch
Prev: RE: Revision tracking on vendor supplied updates? Dalesio, Leo
Next: RE: CAJ or PV gateway problem? Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CAJ or PV gateway problem? Dirk Zimoch
Next: Re: CAJ or PV gateway problem? Matej Sekoranja
