Hi Cyrus,
Interesting, thanks for the report.
Perhaps if I specify the universal flag from the beginning it will work.
I will give it another try once my dad isn't using his new laptop ;)
Bertrand
On Dec 21, 2009, at 7:33 PM, Cyrus Reed wrote:
I was able to get it to work about a month ago when compiling EPICS
for my Snow Leopard install. I just checked my ports and it doesn't
think anything is out of date, so I think if you are using the
latest MacPorts (1.8.1) it should work. I didn't run into any
MacPorts build problems - I added the +universal variant to the "/
opt/local/etc/macports/variants.conf" file before I built anything,
however. (Well, this isn't strictly true - I built everything with
the defaults first, and then when I ran into the same "file not of
required architecture" problem you did, uninstalled the MacPorts
tree and started over using the universal flag...) I then built
EPICS using the default of 32-bits; so far everything seems to be
working OK. (I use MEDM, ALH, and StripTool mostly - Probe does
have some graphics layout issues that I think are related to the
version of openmotif (2.3.2) installed by MacPorts.) I can't say
what's wrong with your build, but thought I would throw out a report
that it's possible to get it to work... As a last resort you might
try wiping out your MacPorts install and starting that over - some
of the things I read about MacPorts suggest this is sometimes
necessary if things seem to be broken.
-Cyrus
Cyrus Reed
Operations Specialist
LIGO Hanford Observatory
On Dec 21, 2009, at 3:55 PM, Bertrand H.J. Biritz wrote:
Hi Andrew,
Thanks for the info.
Poor Janet and in fact all of the EPICS developers who constantly
need to update the code in order to compile properly on all the
various architectures – it certain keeps everyone busy :) It is
much appreciated by all of us who rely on you!
In MacPorts I just tried installing openmotif with the "universal"
variant but one of the dependences failed to compile:
<snip>
Building Xft2
Error: Target org.macports.build returned: shell command " cd "/opt/
local/var/macports/build/
_opt_local_var_macports_sources_rsync
.macports.org_release_ports_x11_Xft2/work/libXft-2.1.14" && /usr/
bin/make -j2 all " returned error 2
Command output: "_FcUtf8ToUcs4", referenced from:
_XftDrawStringUtf8 in xftdraw.o
_XftTextExtentsUtf8 in xftextent.o
_XftTextRenderUtf8 in xftrender.o
<snip>
So, unless I did something incorrect it looks like there is an
impasse for a while.
Bertrand
On Dec 21, 2009, at 3:39 PM, Andrew Johnson wrote:
On Monday 21 December 2009 13:56:09 Eric Norum wrote:
To build EPICS for 64-bit only, edit
I don't recommend this if you're wanting to build and run alh or
StripTool
with the result; AIUI neither of those programs works very well
(if at all)
when built for 64-bit. Janet has fixing them on her To Do list,
but I don't
know how long it's going to take. MEDM seems to be Ok though.
I guess that's one of the disadvantages of using the Darwin
universal 32/64
build configuration, all the code has to work properly on both
configurations.
- Andrew
The best FOSS code is written to be read by other humans -- Harald
Welte
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
- Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Eric Norum
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Andrew Johnson
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Cyrus Reed
[BUG?] dbgrep *O > /tmp/toto Emmanuel Mayssat
<2009>
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
