I was able to get it to work about a month ago when compiling EPICS for my Snow Leopard install. I just checked my ports and it doesn't think anything is out of date, so I think if you are using the latest MacPorts (1.8.1) it should work. I didn't run into any MacPorts build problems - I added the +universal variant to the "/opt/local/etc/macports/variants.conf" file before I built anything, however. (Well, this isn't strictly true - I built everything with the defaults first, and then when I ran into the same "file not of required architecture" problem you did, uninstalled the MacPorts tree and started over using the universal flag...) I then built EPICS using the default of 32-bits; so far everything seems to be working OK. (I use MEDM, ALH, and StripTool mostly - Probe does have some graphics layout issues that I think are related to the version of openmotif (2.3.2) installed by MacPorts.) I can't say what's wrong with your build, but thought I would throw out a rep!
ort that it's possible to get it to work... As a last resort you might try wiping out your MacPorts install and starting that over - some of the things I read about MacPorts suggest this is sometimes necessary if things seem to be broken.
-Cyrus
Cyrus Reed
Operations Specialist
LIGO Hanford Observatory
On Dec 21, 2009, at 3:55 PM, Bertrand H.J. Biritz wrote:
> Hi Andrew,
> Thanks for the info.
> Poor Janet and in fact all of the EPICS developers who constantly need to update the code in order to compile properly on all the various architectures – it certain keeps everyone busy :) It is much appreciated by all of us who rely on you!
> In MacPorts I just tried installing openmotif with the "universal" variant but one of the dependences failed to compile:
> <snip>
> Building Xft2
> Error: Target org.macports.build returned: shell command " cd "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_Xft2/work/libXft-2.1.14" && /usr/bin/make -j2 all " returned error 2
> Command output: "_FcUtf8ToUcs4", referenced from:
> _XftDrawStringUtf8 in xftdraw.o
> _XftTextExtentsUtf8 in xftextent.o
> _XftTextRenderUtf8 in xftrender.o
> <snip>
> So, unless I did something incorrect it looks like there is an impasse for a while.
> Thanks,
> Bertrand
> On Dec 21, 2009, at 3:39 PM, Andrew Johnson wrote:
>> On Monday 21 December 2009 13:56:09 Eric Norum wrote:
>>> To build EPICS for 64-bit only, edit
>> I don't recommend this if you're wanting to build and run alh or StripTool
>> with the result; AIUI neither of those programs works very well (if at all)
>> when built for 64-bit. Janet has fixing them on her To Do list, but I don't
>> know how long it's going to take. MEDM seems to be Ok though.
>> I guess that's one of the disadvantages of using the Darwin universal 32/64
>> build configuration, all the code has to work properly on both configurations.
>> - Andrew
>> The best FOSS code is written to be read by other humans -- Harald Welte
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
- Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Eric Norum
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Andrew Johnson
[BUG?] dbgrep *O > /tmp/toto Emmanuel Mayssat
<2009>
<2009>
