Hi Andrew,
Thanks for the info.
Poor Janet and in fact all of the EPICS developers who constantly need
to update the code in order to compile properly on all the various
architectures – it certain keeps everyone busy :) It is much
appreciated by all of us who rely on you!
In MacPorts I just tried installing openmotif with the "universal"
variant but one of the dependences failed to compile:
<snip>
Building Xft2
Error: Target org.macports.build returned: shell command " cd "/opt/
local/var/macports/build/
_opt_local_var_macports_sources_rsync
.macports.org_release_ports_x11_Xft2/work/libXft-2.1.14" && /usr/bin/
make -j2 all " returned error 2
Command output: "_FcUtf8ToUcs4", referenced from:
_XftDrawStringUtf8 in xftdraw.o
_XftTextExtentsUtf8 in xftextent.o
_XftTextRenderUtf8 in xftrender.o
<snip>
So, unless I did something incorrect it looks like there is an impasse
for a while.
Bertrand
On Dec 21, 2009, at 3:39 PM, Andrew Johnson wrote:
On Monday 21 December 2009 13:56:09 Eric Norum wrote:
To build EPICS for 64-bit only, edit
I don't recommend this if you're wanting to build and run alh or
StripTool
with the result; AIUI neither of those programs works very well (if
at all)
when built for 64-bit. Janet has fixing them on her To Do list, but
I don't
know how long it's going to take. MEDM seems to be Ok though.
I guess that's one of the disadvantages of using the Darwin
universal 32/64
build configuration, all the code has to work properly on both
configurations.
- Andrew
The best FOSS code is written to be read by other humans -- Harald
Welte
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Cyrus Reed
- Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Eric Norum
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Andrew Johnson
RE: september cut Jeff Hill
<2009>
<2009>
