Hi Eric,
I will try again once my dad no longer is using the machine :)
How do I force the EPICS 64-bit compilation?
Bertrand
On Dec 21, 2009, at 1:47 PM, Eric Norum wrote:
Looks like you have a few options.
1) Rebuild EPICS as 64-bit.
2) Rebuild the X11/Motif stuff as 32-bit.
3) Rebuild EPICS and X11/Motif as universal 32/64-bit.
I don't think that there's any problem with a 32-bit kernel running
64-bit applications.
Maybe EpicsHostArch.pl needs to be modified to emit x86_64 on
appropriate architectures?
On Dec 21, 2009, at 10:37 AM, Bertrand H.J. Biritz wrote:
Hi Eric,
I didn't change whatever the default compilation is – just
downloaded the various EPICS components and made the usual changes:
setting the environmental variable EPICS_HOST_ARCH (darwin-x86
according to EpicsHostArch.pl) and for the extensions defining to
use MacPort instead of Fink.
One thing to note is the kernel isn't running in 64-bit mode.
Bertrand
On Dec 21, 2009, at 1:12 PM, Eric Norum wrote:
Are all your EPICS compiles specifying the 64-bit architecture as
well?
On Dec 21, 2009, at 9:56 AM, Bertrand H.J. Biritz wrote:
Hi Eric,
Here is the output:
file /opt/local/lib/libX*
/opt/local/lib/libX11.6.3.0.dylib: Mach-O 64-bit dynamically
linked shared library x86_64
/opt/local/lib/libX11.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libX11.a: current ar archive random
library
/opt/local/lib/libX11.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libX11.la: libtool library file
/opt/local/lib/libXau.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXau.a: current ar archive random
library
/opt/local/lib/libXau.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXau.la: libtool library file
/opt/local/lib/libXdmcp.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXdmcp.a: current ar archive random
library
/opt/local/lib/libXdmcp.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXdmcp.la: libtool library file
/opt/local/lib/libXext.6.4.0.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXext.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXext.a: current ar archive random
library
/opt/local/lib/libXext.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXext.la: libtool library file
/opt/local/lib/libXft.2.1.13.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXft.2.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXft.a: current ar archive random
library
/opt/local/lib/libXft.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXft.la: libtool library file
/opt/local/lib/libXm.4.0.2.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXm.4.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXm.a: current ar archive random
library
/opt/local/lib/libXm.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXm.la: libtool library file
/opt/local/lib/libXmu.6.2.0.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXmu.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXmu.a: current ar archive random
library
/opt/local/lib/libXmu.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXmu.la: libtool library file
/opt/local/lib/libXmuu.1.0.0.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXmuu.1.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXmuu.a: current ar archive random
library
/opt/local/lib/libXmuu.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXmuu.la: libtool library file
/opt/local/lib/libXp.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXp.a: current ar archive random
library
/opt/local/lib/libXp.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXp.la: libtool library file
/opt/local/lib/libXrender.1.3.0.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXrender.1.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXrender.a: current ar archive random
library
/opt/local/lib/libXrender.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXrender.la: libtool library file
/opt/local/lib/libXt.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXt.a: current ar archive random
library
/opt/local/lib/libXt.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXt.la: libtool library file
Bertrand
Quoting Eric Norum <[email protected]>:
Run
to tell you about the architectures supported by your MacPorts
Motif installation.
Eric Norum
[email protected]
Eric Norum
[email protected]
Eric Norum
[email protected]
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Eric Norum
- Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
<2009>
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
