Hi Steve,
Thanks for the suggestion, sadly it didn't make a difference. When
trying to compile alh it still errors out at the same point.
I need to take a closer look at the Makefiles and see whether changing
the order of the include libraries makes a difference – the system
ones are of a newer vintage than the MacPort ones.
Bertrand
On Dec 21, 2009, at 9:04 AM, Steve Shoaf wrote:
Bertrand,
gcc on Snow Leopard defaults to 64-bit compiling, Xcode projects
apparently default to 32-bit. As of R3.14.11 EPICS base does not
have support in the build files for darwin-x86_64. The "file is not
of required architecture" came up when I was compiling some of my
darwin R3.14.11 soft ioc's at the APS when I was upgraded to Snow
Leopard. If you add the following to your CONFIG_SITE file, then
gcc will build and link for 32-bit.
ARCH_DEP_CFLAGS += -m32 -arch i386
ARCH_DEP_LDFLAGS += -arch i386
Hope that resolves your issue,
Steve Shoaf
On Dec 20, 2009, at 9:58 AM, Bertrand H.J. Biritz wrote:
Dear Tech-Talk,
It's the holiday season which means new computer (for my dad this
time) and also compiling code :)
So I tried installing EPICS et al. on a MacBook Pro (2.53 GHz)
running 10.6.2 with MacPorts 1.8.1.
EPICS 3.14.11 went fine, although I needed to deactivate readline
(6.0.000_2+darwin) as it caused an error – hopefully a problem on
their end as the package is still in dev, but just in case here is
the error message
<snip>
../../../../bin/darwin-x86/antelope -l -d ../parse.y
dyld: Symbol not found: _rl_insert
Referenced from: /Users/Superior/Documents/EPICS/base-3-14-11/lib/
darwin-x86/libCom.3.14.11.dylib
Expected in: flat namespace
<snip>
When I try to compile the latest version of the alarm handler or
MEDM I get the following error message:
<snip>
ld: warning: in /opt/local/lib/libXmu.dylib, file is not of
ld: warning: in /opt/local/lib/libXm.dylib, file is not of required
architecture
ld: warning: in /opt/local/lib/libXt.dylib, file is not of required
architecture
ld: warning: in /opt/local/lib/libX11.dylib, file is not of
Undefined symbols:
"_XtAppAddActions", referenced from:
_awRowWidgets in awAlh.o
<snip>
I double checked the CONFIG_SITE.darwin-x86.darwin-x86 file to make
sure it is looking in the correct locations:
# XDarwin
X11_LIB=/usr/X11R6/lib
X11_INC=/usr/X11R6/include/X11
XPM_LIB=/usr/X11R6/lib
XPM_INC=/usr/X11R6/include/X11
# Fink OpenMotif
#MOTIF_LIB=/sw/lib
#MOTIF_INC=/sw/include
# DarwinPorts OpenMotif
MOTIF_LIB=/opt/local/lib
MOTIF_INC=/opt/local/include
Looking in the XDarwin directory there are three of the four .dylib
libraries (libXm.dylib isn't there).
Does someone have an idea of why the compilation is failing? Is it
due to the X11 not being the latest version? On my PowerBook I have
XQuartz 2.4.0 installed, but the XQuartz project said there would
be a separate release called 2.4.1 for Snow Leopard.
Bertrand
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Eric Norum
- Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Pelaia II, Tom
<2009>
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
