1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Remote I/O
To: <[email protected]>
Date: Wed, 16 Dec 2009 12:25:38 -0500
In my previous jobs, I had used Koyo and AutomationDirect equipment
extensively, and like it quite a bit.
Unfortunately, here we were looking for a minimum of a SIL-1 rating on
almost all of the equipment, which I understood at the time, that the
AutomationDirect hardware had not received.
It was also desired that we only select/support 1 or 2 equipment vendors,
and there were requirements for SIL-2 and SIL-3 equipment, which was not
available from AutomationDirect.  That also knocked Yokagawa out of the
running, although I understand we could have worked on getting separate
approval for.
David
On 12/16/09 12:03 PM, "Pete R. Jemian" <[email protected]> wrote:
> Nick:
> Like Mark, my experience with the Koyo PLCs is that they are reliable and
> low-cost.
> They were exceptional for an entry-level system as there was very good
> documentation
> supplied before and after purchase and good support from the distributor.
> Also, the high uptime of this simple systems is much appreciated by beam line
> staff.
> (For example, their output bits don't have to toggle when an IOC is rebooted.)
> Several of our APS beam lines use the Koyo PLCs, mostly for implementation of
> equipment protection systems.  Mark's EPICS support for Modbus/TCP
> communications
> with the Koyo PLCs has been valuable.
> The Koyo PLCs will fail the NSLS2 requirement for
>> 4. Ability to produce and accept configurations and programs in a supported
>> text format
> This is of minor concern if you are not interested in running user code on the
> PLC.
> But, for example, reading of ADC channels on the Koyo can be enhanced
> significantly
> by running user code on the PLC.
> The field experience with the Koyo PLCs (and this is likely common to other
> vendors)
> is high reliability and easy field maintenance.
> As APS has learned with our EPICS brick project, the Linux IOC may have
> a cost advantage over the VME-based IOC if one can reduce or eliminate
> any custom hardware that runs in the Linux IOC.  Otherwise, the cost
> savings is lost in field maintenance and the rapid obsolescence cycle of
> the Linux platform hardware.
> Regards,
>     Pete
> Mark Rivers wrote:
>> Nick,
>> On a relatively small scale I've been pleased with the Modbus/TCP interface
>> to Koyo PLCs from Automation Direct. These PLCs allow direct communication
>> with the I/O points through Modbus.  Some other manufacturers only allow
>> Modbus access to memory registers, which the PLC program must read/write with
>> the I/O point value.  There is a scanner running, but the Koyo PLCs are very
>> inexpensive so cost is really not much of an issue.
>> Mark
>> ________________________________
>> From: [email protected] on behalf of [email protected]
>> Sent: Wed 12/16/2009 6:44 AM
>> To: [email protected]
>> Subject: Remote I/O
>> At Diamond we are considering what to use for the next generation of
>> discrete I/O. Currently we have a lot of VME based hardware, but we are
>> considering a good architecture for a Linux world.
>> The model that we are considering is a soft IOC on a Linux system
>> communicating over Ethernet using an open, industry standard protocol to
>> distributed DIN-Rail mounted I/O points. These I/O points take in
>> Ethernet and are powered from a 24V bus that will run around the
>> hardware area.
>> This eliminates any dependence on a specialized bus architecture (apart
>> from Ethernet) on the Linux system, so they can be commodity PC's, and
>> hopefully allows us to use widely available, cheap, industrial modules
>> for I/O. It will not completely replace all of the requirements
>> currently serviced by VME, but would be able to satisfy most of them,
>> with the remaining few being serviced by the occasional VME system (or
>> FPGA, or some other bus, or something else entirely in the future...).
>> This email is to poll the EPICS community as to the experience people
>> have had, and recommendations for and against.
>> The sort of thing we have identified are:
>>  1. Modbus/TCP based modules, such as the Acromag Busworks series
>> http://www.acromag.com/models.cfm?Product_Function_ID=28&Category_ID=22&;
>> Group_ID=2
>>  2. EtherCAT base modules, such as those from Beckhoff:
>> http://www.beckhoff.com/
>>  3. Standard PLC systems where (as distinct from the other two), you
>> take Ethernet to a PLC controller which then has a series of modules it
>> talks to in a variety of possible ways.
>> So, is anyone willing to share their experiences with these or similar
>> systems,
>> Cheers,
>> Nick Rees
>> Principal Software Engineer           Phone: +44 (0)1235-778430
>> Diamond Light Source                  Fax:   +44 (0)1235-446713
>> This e-mail and any attachments may contain confidential, copyright and or
>> privileged material, and are for the use of the intended addressee only. If
>> you are not the intended addressee or an authorised recipient of the
>> addressee please notify us of receipt by returning the e-mail and do not use,
>> copy, retain, distribute or disclose the information in or attached to the
>> e-mail.
>> Any opinions expressed within this e-mail are those of the individual and not
>> necessarily of Diamond Light Source Ltd.
>> Diamond Light Source Ltd. cannot guarantee that this e-mail or any
>> attachments are free from viruses and we cannot accept liability for any
>> damage which you may sustain as a result of software viruses which may be
>> transmitted in or with the message.
>> Diamond Light Source Limited (company no. 4375679). Registered in England and
>> Wales with its registered office at Diamond House, Harwell Science and
>> Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
Re: Remote I/O Pete R. Jemian
Prev: RE: Remote I/O Mark Rivers
Next: Re: Remote I/O Stephen Lewis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Remote I/O Pete R. Jemian
Next: RE: Remote I/O nick.rees
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
