1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Remote I/O
To: <[email protected]>
Date: Wed, 16 Dec 2009 08:39:22 -0500
I am currently in the process of researching the exact same thing.  We're
using Allen Bradley PLC's in the new NSLS-2 control architecture, and I'm
currently working on extending the Ethernet/IP driver to connect directly to
the various Point I/O, Flex I/O and ArmorPoint I/O modules.
The ArmorPoint and ArmorBlock modules seem to be the most useful of the I/O
blocks I'm researching, as they have integrated Ethernet/IP interfaces (some
with an integrated 2 and 3 port switch), can provide various levels of I/O,
and are ruggedized to the degree we can easily install them on the
experimental floor.
David
On 12/16/09 7:44 AM, "[email protected]" <[email protected]>
wrote:
> At Diamond we are considering what to use for the next generation of
> discrete I/O. Currently we have a lot of VME based hardware, but we are
> considering a good architecture for a Linux world.
> The model that we are considering is a soft IOC on a Linux system
> communicating over Ethernet using an open, industry standard protocol to
> distributed DIN-Rail mounted I/O points. These I/O points take in
> Ethernet and are powered from a 24V bus that will run around the
> hardware area.
> This eliminates any dependence on a specialized bus architecture (apart
> from Ethernet) on the Linux system, so they can be commodity PC's, and
> hopefully allows us to use widely available, cheap, industrial modules
> for I/O. It will not completely replace all of the requirements
> currently serviced by VME, but would be able to satisfy most of them,
> with the remaining few being serviced by the occasional VME system (or
> FPGA, or some other bus, or something else entirely in the future...).
> This email is to poll the EPICS community as to the experience people
> have had, and recommendations for and against.
> The sort of thing we have identified are:
>  1. Modbus/TCP based modules, such as the Acromag Busworks series
> http://www.acromag.com/models.cfm?Product_Function_ID=28&Category_ID=22&;
> Group_ID=2
>  2. EtherCAT base modules, such as those from Beckhoff:
> http://www.beckhoff.com/
>  3. Standard PLC systems where (as distinct from the other two), you
> take Ethernet to a PLC controller which then has a series of modules it
> talks to in a variety of possible ways.
> So, is anyone willing to share their experiences with these or similar
> systems,
> Cheers,
> Nick Rees
> Principal Software Engineer           Phone: +44 (0)1235-778430
> Diamond Light Source                  Fax:   +44 (0)1235-446713
Re: Remote I/O Elliott Wolin
Remote I/O nick.rees
Prev: Re: Remote I/O Matthias Clausen
Next: Re: Remote I/O Elliott Wolin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Remote I/O Rolf Keitel
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
