Ernest,
The following code reproduces the vxWorks 6.6 gcc compiler bug (as seen with
EPICS R3.14.11).
[hill@integrity cas]$
/ade/vxWorks/6/gnu/4.1.2-vxworks-6.6/x86-linux2/bin/ccppc -c
-DCPU=PPC604 -DvxWorks -O2 -Wall -mcpu=604 -mstrict-align
-fno-implicit-fp -fno-builtin -MMD -I. -I../O.Common -I. -I..
-I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket
-I../../../../src/cas/generic/st -I../../../../src/cas/../ca
-I../../../../include/os/vxWorks -I../../../../include
-I/ade/vxWorks/6/vxworks-6.6/target/h
-I/ade/vxWorks/6/vxworks-6.6/target/h/wrn/coreip -v
Using built-in specs.
Target: powerpc-wrs-vxworks
Configured with: /scratch/nathan/vxworks/src/gcc-4.1/configure
--build=i686-pc-linux-gnu --host=i686-pc-linux-gnu
--target=powerpc-wrs-vxworks --enable-threads --disable-libmudflap
--disable-libssp --disable-libgomp --disable-libstdcxx-pch
--enable-sjlj-exceptions --disable-hosted-libstdcxx
--enable-version-specific-runtime-libs --with-gnu-as --with-gnu-ld
--enable-languages=c,c++ --disable-shared --disable-hosted-libstdcxx
--with-cxxabi=/scratch/nathan/vxworks/src/dinkum-20021215/include
--with-pkgversion='Wind River VxWorks G++ 4.1-82'
[email protected] --disable-nls --prefix=/opt/codesourcery
--exec-prefix='/opt/codesourcery/x86-linux2'
--libdir='/opt/codesourcery/lib'
--program-transform-name='s,^gcc$,cc,;s,$,ppc,'
--with-gxx-include-dir=''\''/opt/codesourcery/'\''include/c++/4.1'
--with-license=/scratch/nathan/vxworks/powerpc/obj/host-libs-4.1-82-powerpc-
wrs-vxworks-i686-pc-linux-gnu/usr --with-csl-license-version=20071015
--with-csl-license-feature=gcc_Power_VxWorks
--enable-poison-system-directories
Thread model: vxworks
gcc version 4.1.2 (Wind River VxWorks G++ 4.1-82)
-I/ade/vxWorks/6/vxworks-6.6/target/h/wrn/coreip tmp.cc
tmp.cc: In member function 'DblRet Cat::meow()':
tmp.cc:49: error: unable to find a register to spill in class 'FLOAT_REGS'
tmp.cc:49: error: this is the insn:
(insn:HI 30 29 85 3 (set (reg:DF 121 [ D.1042 ])
(mem/s/c:DF (plus:SI (reg/f:SI 113 sfp)
(const_int 8 [0x8])) [9 D.1040+0 S8 A64])) 301
{*movdf_hardfloat32} (insn_list:REG_DEP_ANTI 29 (nil))
(nil))
------------------------snip-snip------------------
class DblRet {
public:
DblRet ();
private:
double delay;
struct Cow {
void milk ();
private:
void moo ();
class Fish
public:
Fish ( int & );
~Fish ();
inline Fish :: Fish ( int & )
inline Fish :: ~Fish ()
inline void Cow :: milk ()
extern int & fishy;
Fish fish ( fishy );
moo ();
class Cat {
public:
DblRet meow ();
private:
Cow * m_pCow;
DblRet Cat :: meow ()
m_pCow->milk ();
return DblRet ();
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
> -----Original Message-----
> From: Ernest L. Williams Jr. [mailto:[email protected]]
> Sent: Wednesday, December 09, 2009 12:46 PM
> To: Jeff Hill
> Cc: 'Andrew Johnson'; 'Yves Lussignol'; [email protected]; 'Jean-
> Francois Gournay'; [email protected]; 'Eric Bjorklund'; Ernest L.
> Williams Jr.
> Subject: Re: Any News on EPICS 3.14.11 with vxWorks 6.7
> Jeff Hill wrote:
> > Hi Ernest,
> > Executive summary:
> > 1) Apparently, GCC doesn?t fail with the MVME550 but this is very
> similar
> > processor. What -mcpu flag was used with the MVME5500?
> Not sure, if they have a separate CONFIG file for MVME5500
> What we have with the distribution of BASE from APS is the following:
> <>/configure/os/CONFIG.Common.vxWorks-ppc604
> The flag is :
> ARCH_DEP_CFLAGS_4 = -mcpu=604 -mstrict-align -fno-implicit-fp
> > 2) I will need to try to reproduce it here with our vxWorks 6.6. That
> will
> > require installation of EPICS R3.14.11 onto a new host here.
> Okay, be sure to use the latest GNU Compiler patches from Windriver:
> > 3) I wonder if -mcpu=604e or -mcpu=7450 would a closer match to the
> board;
> > perhaps that?s worth a try.
> I tried both options; still does not work. Fails the same way.
> > Sorry about the delay responding, Los Alamos was, for all practical
> > purposes, in stasis yesterday due to snow, wind, and power outages (I
> spent
> > most of the day shoveling out three driveways).
> > A quick review of the current situation is in order. There was a no-
> altivec
> > flag for the C++ compiler that might have helped, but it didn?t, and now
> we
> > see that the issue does not occur with the MVME5500 but does occur with
> the
> > MVME6600. The MVME5500 has an MPC7455 processor chip and the MVME6100
> has an
> > MPC7457 processor chip. We are using -mcpu=604 when the compiler fails,
> and
> > I am not sure what -mcpu option was used for the MVME5500 when it did
> > compile. Perhaps -mcpu=604e or -mcpu=7450 would be worth trying?
> Again, I tried the different mcpu flags that you recommended. Still no
> change; build fails.
> By the way build for PPC603 architecture builds just fine. :)
> I am only having a problem with PPC604
> > http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MPC7457
> > http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MPC7455
> > I don?t claim to have read up on the subtle differences between these
> chips.
> > Nevertheless, the compiler should produce object code for the supported
> CPU
> > architecture that we select so we have a compiler bug; we are just
> looking
> > for a workaround when selecting different architectures.
> I need some work-around in the cas source code; I definitely need this
> because of the PV Gateway dependencies.
> > I _have_ tried to reproduce this in a small code but this is time
> consuming
> > because we have been using Ernest's compiler to test. I will need to try
> to
> > reproduce it here.
> > Jeff
> >> Sent: Tuesday, December 08, 2009 10:27 AM
> >> To: Jeff Hill
> >> Cc: Andrew Johnson; Yves Lussignol; [email protected]; Jean-
> Francois
> >> Gournay; [email protected]; Ernest L. Williams Jr.
> >> Subject: Any News on EPICS 3.14.11 with vxWorks 6.7
> >> Hi Jeff,
> >> Just wanted to follow up on the issue with vxWorks GNU compiler:
> >> I don't understand why our colleagues don't see this problem?
> >> /afs/slac/package/vxworks/devel/6.7/gnu/4.1.2-vxworks-6.7/x86-
> >> linux2/bin/ccppc
> >> -c -DCPU=PPC604 -DvxWorks -DBSD=44 -g -Wall
> >> -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -fno-builtin
> >> -DBSD=44 -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic
> >> -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st
> >> -I../../../../src/cas/../ca -I../../../../include/os/vxWorks
> >> -I/afs/slac/package/vxworks/devel/6.7/vxworks-6.7/target/h
> >> -I/afs/slac/package/vxworks/devel/6.7/vxworks-6.7/target/h/wrn/coreip
> >> ../../../../src/cas/generic/st/casStreamOS.cc
> >> In file included from
> >> /afs/slac/package/vxworks/devel/6.7/vxworks-6.7/target/h/taskLib.h:257,
> >> from
> >> 6.7/target/h/private/selectLibP.h:24,
> >> from
> 6.7/target/h/selectLib.h:75,
> >> from ../../../../include/os/vxWorks/osdSock.h:35,
> >> from ../../../../include/osiSock.h:21,
> >> from ../../../../include/fdManager.h:28,
> >> from ../../../../src/cas/generic/st/casStreamOS.cc:18:
> 6.7/target/h/vsbConfig.h:42:2:
> >> warning: #warning "VxWorks Source Build (VSB) project not specified;
> >> using default VxWorks UP configuration under
> >> $WIND_BASE/target/lib/h/config"
> >> ../../../../src/cas/generic/st/casStreamOS.cc: In member function
> >> 'virtual epicsTimerNotify::expireStatus casStreamIOWakeup::expire(const
> >> epicsTime&)':
> >> ../../../../src/cas/generic/st/casStreamOS.cc:283: error: unable to
> find
> >> ../../../../src/cas/generic/st/casStreamOS.cc:283: error: this is the
> >> insn:
> >> (insn 162 161 163 9 ../../../../src/cas/generic/st/casStreamOS.cc:280
> >> (set (reg:DF 119 [ D.21342 ])
> >> (const_int 24 [0x18])) [0 D.21330+0 S8 A64])) 301
> >> {*movdf_hardfloat32} (nil)
> >> (nil))
> >> ../../../../src/cas/generic/st/casStreamOS.cc:283: confused by earlier
> >> errors, bailing out
> >> make[4]: *** [casStreamOS.o] Error 1
> >> make[4]: Leaving directory
> >> `/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-R3-14-
> >> 11/src/cas/build/O.vxWorks-ppc604_long'
> >> make[3]: *** [install.vxWorks-ppc604_long] Error 2
> >> make[3]: Leaving directory
> >> 11/src/cas/build'
> >> make[2]: *** [build.install] Error 2
> >> make[2]: Leaving directory
> >> `/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-R3-14-11/src/cas'
> >> make[1]: *** [cas.install] Error 2
> >> make[1]: Leaving directory
> >> `/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-R3-14-11/src'
> >> Thanks,
> >> Ernest
- Re: Any News on EPICS 3.14.11 with vxWorks 6.7 Ernest L. Williams Jr.
Re: Fwd: CA link behavior Andrew Johnson
Re: Odd widget layout in EDM on OS X Noboru Yamamoto
<2009>
Re: Odd widget layout in EDM on OS X Eric Norum
<2009>
