I agree with Dirk's statement.
I would like to add, though, that currently if the D.INP link is A.CP
(or D is passive and D.INP is A.CPP), D *will* get processed when the CA
link is set up, independent from its PINI value. Reason: .CP and .CPP
input links are implemented as CA monitors, and will get a value when
the connection comes up. At that point, that first incoming value update
is not distinguished from later updates, and the record is processed.
Again: I agree with Dirk that D should probably just be initialized, not
processed on reboot of ioc2.
But I'm not sure if that can be implemented easily (records may have
many .CP inputs, so checking UDF is not sufficient), and I want to point
out this would introduce a serious change in behavior, that could
possibly break many existing databases.
I can see the unexpected string type link behavior possibly being
intended to do something like an auto-save/restore on record C. This
could be an interesting feature, if (and only if) it is independent from
data type (obviously) and configurable (which requires a CA protocol
change to allow the link spec to define target record processing -
instead of the PP option of the target field now used for that purpose).
Cheers,
Ralph
On Wed 09 Dec 2009 4:58:26 Dirk Zimoch wrote:
Hi Andrew,
My personal opinion is that a record which is not processed should not
"do" anything. That means it should not cause other records to process
and should not change their value. I think the original idea behind
processing a record is that this is the only time where a record is
"active". Maybe apart from the time when it initializes. But even then
it should not process other records.
Let's assume this situation:
ioc1:
A
B.OUT-> C
ioc2:
C
D.INP -> A
I think the "correct" behavior is:
When ioc2 reboots, C becomes INVALID/UDF and only gets a copy of B
when B processes. D gets initialized with a copy of A. Neither C nor D
gets processed unless they have PINI set.
Dirk
- Re: Fwd: CA link behavior Andrew Johnson
- Re: CA link behavior Andrew Johnson
- Fwd: CA link behavior Geoff Savage
- Re: Fwd: CA link behavior Dirk Zimoch
Re: EDM on Cygwin Ernest L. Williams Jr.
Odd widget layout in EDM on OS X Eric Norum
<2009>
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
