1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Asyn On Cygwin
To: "Pawel Kowalski - BiRa Systems Inc." <[email protected]>, <[email protected]>
Date: Tue, 8 Dec 2009 15:18:26 -0600
The problem is that the Cygiwn build only works with STATIC_BUILD=YES, SHARED_LIBRARIES=NO.  Change your CONFIG_SITE.cygwin32-cygwin32 to select these options and rebuilt base and asyn.
From: [email protected] [mailto:[email protected]] On Behalf Of Pawel Kowalski - BiRa Systems Inc.
Sent: Tuesday, December 08, 2009 3:14 PM
To: [email protected]
Subject: Asyn On Cygwin
Hello,
I am trying to move an application we set up on an openSuse linux distribution to a windows machine running cygwin. I am trying to compile Asyn on cygwin and I am running in to trouble. I attached the console output. Before I got this error I had another issue with the command rpcgen so I went ahead and installed the Sun RPC package which was hopefully the right package to install (it did fix the error with rpcgen not being found). Thank you in advance, help would be appreciated.
Pawel Kowalski
BiRa Systems Inc.
www.bira.com
Phone:                   505-881-8887
Fax:                       505-888-0651
Address:                2410 Midtown PL NE
STE A
Albuquerque NM 87107 USA
RE: Asyn On Cygwin Pawel Kowalski - BiRa Systems Inc.
Prev: Asyn On Cygwin Pawel Kowalski - BiRa Systems Inc.
Next: RE: Asyn On Cygwin Pawel Kowalski - BiRa Systems Inc.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
