1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: polling through the gateway
To: Geoff Savage <[email protected]>
Cc: Tech-talk Talk <[email protected]>
Date: Tue, 08 Dec 2009 11:33:11 +0100
Hi Geoff,
In the current version, the gateway has the option -no_cache which allows a client to poll through the gateway. The previous version (or when started without -no_cache) has a very strange behavior: Only if no client monitors the channel a poll is passed through to the IOC. If any client monitors a poll does not pass the gateway but instead delivers the last value received by monitor. The problem is that you can hardly know when there is any other client with a monitor.
That is very annoying if you have values that don't cause monitors. For example if HOPR changes dynamically and you do a caget with DBR_CTRL_DOUBLE on the VAL field. Then you would always get the HOPR value at the time when the first client started a monitor on the VAL field. This is because the gateway uses DBR_STS_* for monitors (as most CA clients do). So the HOPR information in the gateway is never updated.
We user the -no_cache option everywhere. The additional overhead is moderate. It is only TCP traffic between gateway and IOC. The gateway still reduces the UDP traffic, so that even a shell script doing caget in a loop does not flood the IOC network with broadcasts.
Of course, polling over the network is generally a bad idea.
Dirk
Geoff Savage wrote:
Is it possible to ask the gateway to poll PVs? Currently the gateway uses monitors when it connects to the PVs on the client side. I would like the gateway to have the equivalent of a SCAN field for a PV name it is reading.
Thanks,  Geoff
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
polling through the gateway Geoff Savage
Prev: GDA goes Open Source Paul.gibbons
Next: Re: Fwd: CA link behavior Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: polling through the gateway Ralph Lange
Next: GDA goes Open Source Paul.gibbons
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
