1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: polling through the gateway
To: Geoff Savage <[email protected]>
Date: Mon, 07 Dec 2009 18:05:04 -0500
Hi Geoff,
Short answer:   No.
Long answer: You are asking for something which would be quite the opposite of what the Gateway was originally intended for, i.e. shielding the IOCs by setting up monitors on the inside that feed into a cache, and answering all outside requests from the cache. This has been extended by the option to not cache data, so that get() requests from the outside are always going through to the IOC. I don't know if adding the option to have the Gateway actively produce CA traffic on the IOC side is a step in the right direction.
Also: Wouldn't a periodically scanned record in a soft IOC behave exactly the way you want?! Adding the feature of periodic scanning on the Gateway would half-way convert it to an IOC, mixing functionalities that I would rather see being kept separate.
Cheers,
Ralph
On Mon 07 Dec 2009 17:23:36 Geoff Savage wrote:
Is it possible to ask the gateway to poll PVs? Currently the gateway uses monitors when it connects to the PVs on the client side. I would like the gateway to have the equivalent of a SCAN field for a PV name it is reading.
Thanks, Geoff
polling through the gateway Geoff Savage
Prev: polling through the gateway Geoff Savage
Next: GDA goes Open Source Paul.gibbons
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: polling through the gateway Dirk Zimoch
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
