Hi Mark,
Here is the result of dbpr "CAM:ASYN:IO",5:
epics> dbpr "CAM:ASYN:IO",5
ACKS: NO_ALARM ACKT: YES ACMD: None ADDR: 12
AINP: AOUT: AQR: 0 ASG:
ASP: 0x00000000 AUCT: autoConnect BAUD: Unknown BINP: 0
BKPT: 0x00 BOUT: 0 CNCT: Connect DBIT:
Unknown
DESC: asyn IO DISA: 0 DISP: 0 DISS:
NO_ALARM
DISV: 1 DPVT: 0xf0f85c09 DRVINFO: DSET:
0x488a5b00
DTYP: asynRecordDevice ENBL: Enable EOMR: None
ERRS: 0xd8fb5c09 EVNT: 0 F64INP: 0 F64IV: 0
F64OUT: 0 FCTL: Unknown FLNK:DB_LINK CAM:FO:IO:DATA
GPIBIV: 1 I32INP: 0 I32IV: 1 I32OUT: 0
IEOS: IFACE: asynOctet IFMT: Binary IMAX: 80
IPTR: 0x28fb5c09 LCNT: 0 LSET: 0xd0d35d09 MCTL:
Unknown
MLIS: 0x000000000000000000000000 MLOK: 0xd8f85c09 NAME:
CAM:ASYN:IO
NAWT: 0 NORD: 0 NOWT: 6 NRRD: 0
NSEV: NO_ALARM NSTA: NO_ALARM OCTETIV: 1 OEOS:
OFMT: Binary OMAX: 80 OPTIONIV: 1 OPTR:
0xd0fa5c09
PACT: 0 PCNCT: Connect PHAS: 0 PINI: NO
PORT: L0 PPN: 0x00000000 PPNR: 0x00000000 PRIO: LOW
PROC: 0 PRTY: Unknown PUTF: 0 RDES:
0x58855909
REASON: 0 RPRO: 0 RSET: 0x008a5b00 SBIT:
Unknown
SCAN: Passive SDIS:CONSTANT SEVR: NO_ALARM SOCK:
SPR: 0 SPVT: 0x00000000 STAT: NO_ALARM TB0: On
TB1: Off TB2: Off TB3: Off TB4: Off
TFIL: Unknown TIB0: Off TIB1: Off TIB2: Off
TIME: 2009-12-06 08:51:04.871003000 TINP: TIOM: 0
TMOD: Write/Read TMOT: 1 TMSK: 1 TPRO: 0
TSE: 0 TSEL:CONSTANT TSIZ: 80 UCMD: None
UDF: 0 UI32INP: 0 UI32IV: 0 UI32MASK:
4294967295
UI32OUT: 0 VAL:
epics>
Zen
-----Original Message-----
Sent: Saturday, December 05, 2009 9:43 PM
To: Szalata, Zenon M.; Eric Norum
Cc: TECHTALK Tech-Talk
Subject: RE: asyn R4.10, R4.11, R4.12
Are you using the asyn record? If so, then do a
dbpr "myAsynRecord" 5
to see what you have set the EOS string to.
From: [email protected] on behalf of Szalata, Zenon M.
Sent: Sat 12/5/2009 11:38 PM
To: Eric Norum
I am not aware of explicitly specifying the EOS string. I thought that
EOS string was not used and only the EOI was. That is, the KS3988 GPIB
CAMAC crate controller does not require nor accepts an EOS string. I
maybe wrong on this. Perhaps, somehow unwittingly I am sending some EOS
string? How can I verify that?
Actually, in my original message I told a lie, I am not using
streamdevice, just asyn.
Why does it work with asyn R4.9 and not with the newer versions? Is it
possible that starting with R4.10 default behavior changed? Could it
be, that starting with R4.10 I have to explicitly say no EOS?
Zen
Sent: Saturday, December 05, 2009 9:01 PM
Subject: Re: asyn R4.10, R4.11, R4.12
The E5810A allows only a single EOS character. Are you trying to use a
longer end-of-string?
On Dec 5, 2009, at 8:51 PM, Szalata, Zenon M. wrote:
> Hi Eric,
> I am using Agilent E5810A.
> Here is a line from the st.cmd file:
> vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
> Thank you,
> Zen
> From: Eric Norum [mailto:[email protected]]
> Sent: Saturday, December 05, 2009 8:35 PM
> What GPIB controller are you using?
> On Dec 5, 2009, at 5:42 PM, Szalata, Zenon M. wrote:
>> I have a simple soft IOC which uses asyn and streamdevice. It does
IO
>> with KS3988 GPIB CAMAC crate controller. The IOC works correctly
with
>> asyn R4.9. I have installed asyn R4.12 and my IOC does not work with
>> asyn R4.12. I get the following message: "EOS TOO LONG". I also
> tried
>> asyn R4.11 and R4.10 I see the same message with these the two
> versions
>> of asyn as I see with the latest.
>> How do I overcome this difficulty? Do these newer versions of asyn
>> require that I make some change to my IOC? Can someone help me with
>> this, please?
>> For now I am forced to stay with asyn R4.9.
>> Thanks,
>> Zen
> Eric Norum
> [email protected]
Eric Norum
[email protected]
- RE: asyn R4.10, R4.11, R4.12 Mark Rivers
- asyn R4.10, R4.11, R4.12 Szalata, Zenon M.
- Re: asyn R4.10, R4.11, R4.12 Eric Norum
- RE: asyn R4.10, R4.11, R4.12 Szalata, Zenon M.
<2009>
<2009>
