1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: asyn R4.10, R4.11, R4.12
To: "Mark Rivers" <[email protected]>, <[email protected]>
Date: Sun, 6 Dec 2009 08:45:39 -0800
Hi Mark,
Actually I made a mistake in my original email.  I am only using asyn.
Here is my st.cmd file:
zms@ilc-esb11 $ less st.cmd
#!../../bin/linux-x86/cam
< envPaths
cd ${TOP}
dbLoadDatabase("dbd/cam.dbd")
cam_registerRecordDeviceDriver(pdbbase)
vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
asynSetTraceIOMask( "L0",12,4)
asynSetTraceMask( "L0",12,0xff)
## Load record instances
dbLoadRecords( "db/blink.db","P=CAM")
dbLoadRecords( "db/camio.db","P=CAM,PORT=L0,A=12")
dbLoadRecords( "db/iosetup.db","P=CAM,V=/nfs/slac/g/testfac/esb/")
dbLoadRecords( "db/timestamp.db","P=CAM")
cd ${TOP}/iocBoot/${IOC}
iocInit()
And here some of the output the IOC generates:
epics>
epics> 2009/12/05 18:05:25.456 L0 addr 12 queueRequest priority 0 not
lockHolder
2009/12/05 18:05:25.457 L0 schedule queueRequest timeout
2009/12/05 18:05:25.457 L0 callback
2009/12/05 18:05:25.457 CAM:ASYN:IO: asynCallbackProcess, state=3
2009/12/05 18:05:25.457 CAM:ASYN:IO flush
2009/12/05 18:05:25.457 CAM:ASYN:IO: EOS TOO LONG
epics>
Thanks Mark,
Zen
-----Original Message-----
Sent: Saturday, December 05, 2009 9:42 PM
To: Szalata, Zenon M.; [email protected]
Hi Zen,
I'm not sure what the problem is.  I am using streamDevice with asyn
R4.12 and I don't have problems.  But I'm using serial, not GPIB.  Eric
Norum is the one who knows most about GPIB.  Hopefully he's getting
settled in Berkeley and will be able to answer your question.
Can you send the exact output of the IOC?  The only occurence of the
string "EOS TOO LONG" that I can find in asyn or streamDevice is in
asynRecord.c.  But you say you are using streamDevice, not the
asynRecord, to talk to the device?
From: [email protected] on behalf of Szalata, Zenon M.
Sent: Sat 12/5/2009 7:42 PM
To: [email protected]
Subject: asyn R4.10, R4.11, R4.12
I have a simple soft IOC which uses asyn and streamdevice.  It does IO
with KS3988 GPIB CAMAC crate controller.  The IOC works correctly with
asyn R4.9.  I have installed asyn R4.12 and my IOC does not work with
asyn R4.12.  I get the following message: "EOS TOO LONG".  I also tried
asyn R4.11 and R4.10 I see the same message with these the two versions
of asyn as I see with the latest.
How do I overcome this difficulty?  Do these newer versions of asyn
require that I make some change to my IOC?  Can someone help me with
this, please?
For now I am forced to stay with asyn R4.9.
Zen
asyn R4.10, R4.11, R4.12 Szalata, Zenon M.
RE: asyn R4.10, R4.11, R4.12 Mark Rivers
Prev: RE: asyn R4.10, R4.11, R4.12 Mark Rivers
Next: RE: asyn R4.10, R4.11, R4.12 Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: asyn R4.10, R4.11, R4.12 Dirk Zimoch
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
