1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: camonitor and caget - displaying unsigned longs in hexadecimal
To: [email protected]
Date: Fri, 4 Dec 2009 17:55:01 -0600
Hi Stephanie,
On Friday 04 December 2009 17:16:34 Allison, Stephanie wrote:
> I notice that camonitor and caget do not honor the "-0x" option (option
> to printout as hex) for PVs that are unsigned long's.  Such PVs are sent
> over CA as double's and -0x is not available for doubles, per design.
> Are there other options that I could use instead?    Should I look into
> changing the tools to allow for -0x for unsigned long's?
CA can't transport unsigned types as such, although the IOC database supports
them.  If you do a cainfo of one of your ULONG PVs you'll see that its native
type actually gets reported as a DBF_DOUBLE, which is the smallest type that
CA can guarantee will pass any ULONG value correctly.  Unfortunately CA gives
no indication of what the real database type is, so I don't think the tool
could properly detect that the field is really a ULONG.
However if you ask caget or camonitor to use DBR_LONG when fetching the value
(add the switch -d LONG) then it does honor the -0x switch, but the display
format is different.  Also if your client is a 64 bit machine you might get
the sign bit extended for display.  This is the output I get on linux-x86_64
when the top bit is set (note that the DBF_LONG and DBR_LONG types are only 32
bits wide even on 64-bit architectures):
tux% caget -d LONG -0x anjHost:compressExample.N
    Native data type: DBF_DOUBLE
    Request type:     DBR_LONG
    Element count:    1
    Value:            0xFFFFFFFF80000000
HTH, HANW,
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
RE: camonitor and caget - displaying unsigned longs in hexadecimal Allison, Stephanie
Prev: camonitor and caget - displaying unsigned longs in hexadecimal Allison, Stephanie
Next: RE: camonitor and caget - displaying unsigned longs in hexadecimal Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
