EPICS on Google+
On Fri, 4 Dec 2009, Rod Nussbaumer wrote: > David Dudley wrote: > > I have a project where I need to cross build some of the EPICS > > extensions for another architecture. > > > > Specifically, I want to build the ChannelArchiver to run on a remote > > Linux host. > > > > I already have the IOS compiled for the host (linux-xscale_be), and it > > works well, with all the libraries and programs functional on that > > architecture, but to make the machine I’m setting up an independent > > system, I need to run the ChannelArchiver as well on that device. > > > > I defined ‘CROSS_COMPILER_TARGET_ARCHS’ in the extensions configure > > directory to ‘linux-xscale_be’, and when I build, I create a xscale_be > > bin directory, however the build system doesn’t pick up the target > > build tools, so it’s building 2 copies of the host programs. > > > > What do I adjust to make the extensions build system pick up the > > proper toolset? > > > > David Dudley > > You will need to create > base/configure/os/CONFIG_SITE.linux-x86.linux-xscale_be > > In it, you can assign to '$GNU_DIR' the path to your cross tools. When > you do this, leave off any trailing 'bin' directory name, as EPICS build > will append this by itself. See the corresponding files for other > architectures as a guide. There already exists a linux-arm_eb target, which should serve: you should just need to edit GNU_DIR and GNU_TARGET in configure/os/CONFIG_SITE.linux-x86.linux-arm_eb GNU_DIR, as Rod says, points to the base directory for your cross compiler, and GNU_TARGET needs to be the compiler target tuple, or to be precise, the prefix in front of your compiler call: eg, I compile with arm-xscale-linux-gnueabi-gcc and so I have GNU_TARGET = arm-xscale-linux-gnueabi
| ANJ, 02 Sep 2010 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
