Hello Jean-Francois,
>>> On Wed, 25 Nov 2009 11:28:00 , "GOURNAY Jean-Francois" <[email protected]> wrote;
> Hello Jeff, hello Kazuro
> Thanks for your replies.
> Jeff,
> I have included the trace of the 2 following commands :
> Dbcar "VMETST-CA-O", "2"
> Casr "1"
> Before these commands, I did a dbtr "VMETST-CA-O", surprisingly UDF
> becomes 0 but the value (supposed to be retrieved through a CA link to
> VMETST) is 0 (it should be "223").
> Both VxWorks IOCs are on the same network (132.166.33.10 and
> 132.166.33.11)
I'm not sure whether I explained the situation well or not. If
you build EPICS without BSD=44, the default EPICS_CA_ADDR_LIST
(or the address list on memory) will not include your broadcast
address, and your IOCs will never communicate each other unless
you specify your broadcast address or host addresses explicitly
into EPICS_CA_ADDR_LIST.
> Kazuro,
> I will pass the information to my colleague in charge of the VxWorks
> support. He had already a lot of trouble with the IP stack of the new
> release of VxWorks (2nd Ethernet port of our MVME5500 not working,
> problem of connection with rlogin, problem with connect function of
> socket.h). Recompiling with gnu instead of diab helps for some point
> (wancomEnd.c) but there are still pending problems.
Our colleagues Tomohiro Okazaki and Takuya Nakamura tested the
2nd Ethernet. Their memo says followings;
1. Apply patches Diab5700_WIND00166270.zip and
WIND00165238-wancom.zip.
2. #define INCLUDE_WANCOM_END in config.h
3. build bootrom, driver, and kernel
make clean bootrom.bin
make CPU=PPC32 TOOL=diab
vxprj build
4. configure the interface
ipAttach 0,"wancom"
ifconfig "wancom0 inet 192.168.1.3 netmask 255.255.255.0 up"
We don't use vxWorks-6.7 yet for production systems, but only
5.3 and 5.5.
> J.F. Gournay
> CEA Saclay
> IRFU/SIS
We'll purchase VME CPU soon. Are there anyone using MVME4100?
Are there good reasons to switch from MVME5500 to MVME4100?
Cheers, Kazuro.
Kazuro FURUKAWA <[email protected]>
Linac&KEKB, High Energy Accelerator Research Organization (KEK), Japan
Telephone: +81-29-864-5200 x4316, Facsimile: +81-29-864-0321
- RE: CA problem w EPICS 3.14.11 & VxWorks 6.7 GOURNAY Jean-Francois
Addition of command primitives to Asyn motor matthew.pearson
<2009>
RE: CA problem w EPICS 3.14.11 & VxWorks 6.7 Jeff Hill
<2009>
