1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: asyn problem
To: [email protected], Mark Rivers <[email protected]>
Date: Fri, 13 Nov 2009 14:56:57 +0530 (IST)
The report(asynReport 10,“L16”) is as follows:
synchronouslock=NO when working properly
ynchronouslock=YES when  not working. other things are as it is except readcount(character)
how can I fix it?
tanushyam
To: "tanushyam bhattacharjee" <[email protected]>, [email protected]
Date: Thursday, 12 November, 2009, 9:42 PM
When it stops working, what do you see?
Here are some things to try:
- When it stops working, issue the following command:
asynReport 10,“L16”
This asks for a detailed report on the state of that asyn port.
Next, issue the following commands:
asynSetTraceIOMask “L16”,0,2
That enables TraceEscape output, printing ASCII plus escape sequences.
asynSetTraceMask “L16”,0,255
That turns on all trace output for your asyn port on address 0.  If you are using other addresses you might need to issue commands like:
asynSetTraceMask “L16”,2,255
for address 2, etc.
This should tell you if you are getting disconnected from the terminal server (TCP/IP disconnect) or if the device is sending garbage, etc.
From: [email protected] [mailto:[email protected]] On Behalf Of tanushyam bhattacharjee
Sent: Thursday, November 12, 2009 9:51 AM
Subject: Fw: asyn problem
--- On Thu, 12/11/09, tanushyam bhattacharjee <[email protected]> wrote:
Subject: asyn problem
Date: Thursday, 12 November, 2009, 8:18 PM
I am using  ‘asyn’ to communicate with a custom made device using ‘HowTodoSerial’ concept where CommonGpib functions are used.
The device continuously sends data if a knob, attached to it, rotates and does not send anything otherwise.
The IOC is working properly as long as the knob rotates but stops working after some time when there is a long gap.The device is connected through a Serial to Ethernet Converter by
drvAsynIPPortConfigure("L16","192.168.0.10:10003",0,0,0)
 in st.cmd file.
TIME_WINDOW=1000
Asyn version=4-4
Base= base-14.8.2
Is it a time out problem? Is it disconnecting from device after timeout?
Additionally I also want to know how can I flush a particular serial buffer in this program?Is flushbuffer function is available here?
tanushyam
Now, send attachments up to 25MB with Yahoo! India Mail. Learn how.
Keep up with people you care about with Yahoo! India Mail. Learn how.
Re: asyn problem Eric Norum
RE: asyn problem Mark Rivers
Prev: RE: asyn problem Mark Rivers
Next: Re: asyn problem Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
