1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Next generation EPICS display manager
To: "Dalesio, Leo" <[email protected]>, Elder Matias <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Cc: "[email protected]" <[email protected]>, "Andrew C. Starritt" <[email protected]>, Andrew Rhyder <[email protected]>, Glen Wright <[email protected]>
Date: Mon, 9 Nov 2009 14:54:16 +1100
At the Australian Synchrotron, we have developed an EPICS Channel Access (CA)/Qt
Framework written entirely in C++.  This allows us to use the Qt Framework to
talk to EPICS directly.
It is available on SourceForge here:
http://sourceforge.net/projects/epicsqt/
This project is a work in progress and we are interested in collaboration with
other labs.
>From a code developers point of view, the framework provides a Qt based interface
to EPICS data using signals, slots and Qt data types, and a set of EPICS aware
widgets that use this interface if needed.
>From a GUI designers point of view, the framework allows the creation of EPICS
GUI systems using only Qt Designer and our GUI application, with no compilation
required.
The framework hierarchy consists of:
* A class providing C++ access to the CA library.
  Provides convenient C++ access to the CA library.
* A Qt based class providing Qt based access to CA.
  Hides CA specific functionality. Adds Qt functionality such as signals and slots.
* A set of classes providing data type independent access.
  Hides EPICS data types, providing read and write conversions where required.
* A set EPICS aware widgets.
  Implements Qt based widgets that provide access to EPICS data.
* A set of EPICS aware graphical Qt plug-ins.
  Adds Qt plug-in interfaces to EPICS aware widgets.
* GUI support widgets and applications.
  Implements Qt based widgets that support control system GUIs. These widgets
  to not access the CA library.
From: [email protected] [[email protected]] On Behalf Of Dalesio, Leo [[email protected]]
Sent: Saturday, 7 November 2009 2:03 AM
To: Elder Matias; [email protected]; [email protected]
Cc: [email protected]; Andrew Rhyder; [email protected]; Glen Wright
At NSLS II, we have recently evaluated the work going on with CSS. We looked over the DESY and ORNL developed tools.
We have found the tools nicely integrated. We find the ability to pass process variable names between applications very useful. It is our plan to develop an advanced directory service and displays to support arrays of channels in the CSS environment.
CSS and Synoptic Displays. There are currently two efforts. They have very different primary goals. The SNS version has a primary need to replace their EDM screens. The DESY version has a primary need to integrate three different control systems. These are both under very active development. As we do not need this for over 1 year, we will sit it out and choose one when the time comes. We believe that both will be viable but may continue to reflect these two different goals. On the other hand, they may converge as they go on. The latest version of both were found reliable. They both have reasonable performance.
The primary interest in this development is the ability to inter-operate between the tools.
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Re: Next generation EPICS display manager Darren Dale
FW: Next generation EPICS display manager tom.cobb
RE: Next generation EPICS display manager Elder Matias
RE: Next generation EPICS display manager Dalesio, Leo
Prev: Re: Qt edm Ralph Lange
Next: Oxford Instruments IPS120-10 Linda.Pratt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Next generation EPICS display manager Dalesio, Leo
Next: Re: Next generation EPICS display manager Darren Dale
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
