1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: File I/O from genSub Process function
To: Till Straumann <[email protected]>
Cc: Techtalk <[email protected]>
Date: Wed, 04 Nov 2009 19:56:15 -0800
Thanks Till!
That was the problem.    CWD was "/" for the genSub Process function
and my startup directory for all the other cases.
- Bruce
Till Straumann wrote:
Are you using relative file paths?
The CWD of the task executing 'Process' may not be what
you think...
T.
Bruce Hill wrote:
I have a genSub I've setup to run test code on my IOC, and I'm getting
errors when I try to read the test set data files. This is an RTEMS 4.7.1 based
IOC accessing an NFS mounted filesystem.     I'm able to read the same
files from a genSub Init function, but not from the Process function.
I can also read these files if I initiate the test from the Cexp shell on the RTEMS
console.
Is there something about how the Process functions are called that would
preclude file I/O?
Thanks!
- Bruce Hill
File I/O from genSub Process function Bruce Hill
Re: File I/O from genSub Process function Till Straumann
Prev: Re: File I/O from genSub Process function Till Straumann
Next: QtCATool Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
