Are you using relative file paths?
The CWD of the task executing 'Process' may not be what
you think...
T.
Bruce Hill wrote:
I have a genSub I've setup to run test code on my IOC, and I'm getting
errors when I try to read the test set data files. This is an RTEMS
4.7.1 based
IOC accessing an NFS mounted filesystem. I'm able to read the same
files from a genSub Init function, but not from the Process function.
I can also read these files if I initiate the test from the Cexp shell
on the RTEMS
console.
Is there something about how the Process functions are called that would
preclude file I/O?
Thanks!
- Bruce Hill
- Re: File I/O from genSub Process function Bruce Hill
- File I/O from genSub Process function Bruce Hill
<2009>
<2009>
