Hi Andrew,
Thank you for this clarification.
Initially I wanted to configure a gensub input as a string with number of element >=2 (string array input),
and initialize it with MACRO substitution.
I understand this is not possible because a string is considered as a CA_LINK.
But can you still answer the following questions:
- is it possible to initialize an array with a MACRO (be it numeric or string) ?
- is it possible to initialize a string array from the startup script using dbpf command or else ?
regards.
Andrew Johnson a écrit :
Hi Christophe,
On Tuesday 27 October 2009 05:50:55 haquin wrote:
I looked in the genSub record code and I think that what I do should work
... After deeper investigations, it turns out that when I initialize the
INPH field type with FTH=STRING or CHAR it is then assigned a CA_LINK type
((*plinkin).type)==CA_LINK instead of CONSTANT ... That's why the Constant
string is not copied at init.
When FTH=LONG then ((*plinkin).type)==CONSTANT
How can I force it to be a CONSTANT
You can't; with the existing database code the link type will be CONSTANT only
if the INPH string is a number. This behavior is a fundamental feature of the
way in which we parse link strings: If the string is completely consumed by
strtod() or strtol() the link type is a CONSTANT; if not and it matches the
name of a local PV it's a DB_LINK, otherwise it must be a CA_LINK.
As an alternative to Tim's suggestion you could put one or more dbpf commands
in your startup script to set the .H field with your string(s), but they must
appear after the iocInit command.
Sorry,
- Andrew
begin:vcard
fn:Christophe Haquin
n:Haquin;Christophe
email;internet:[email protected]
tel;work:02 31 45 46 61
x-mozilla-html:FALSE
version:2.1
end:vcard
- Re: can't initialize record field with string Andrew Johnson
- Re: can't initialize record field with string Bruce Hill
- can't initialize record field with string haquin
- Re: can't initialize record field with string Tim Mooney
- Re: can't initialize record field with string haquin
ICALEPCS 2009 Lifetime Achievement Award Ned Arnold
<2009>
<2009>
