1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: compiling streamDevice with CALC set fails
To: "Dr. Peter Zumbruch" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 23 Oct 2009 16:11:38 +0200
Hi Peter,
Unfortunately, I had no time to test StreamDevice with any EPICS base version newer than 3.14.8.2. Once I find the time -- maybe in 2017 :-) -- I check with newer versions of base and asyn and also on 64 bit architectures. Then I can build a new release.
On the other hand, one can probably live without StreamDevice support for sCalcout records...
Sorry for the inconvenience,
Dirk
Dr. Peter Zumbruch wrote:
Thank you,
doing so I got further but still failed at other places
But after changing
in addition
1) in the streamApp/Makefile
    streamApp_DBD += calc.dbd
        into
    streamApp_DBD += calcSupport.dbd
and
2) added to the <TOP>/configure/RELEASE the line
    SSCAN=<EPICS_TOP>/modules/synApps/synApps_5_4_1/support/sscan/2-6-4
I finally succeeded.
So I did the same what has been done for synApps.
Did I miss some part of documentation in relationship to EPICS 3.14.10
in StreamDevice docs about this
and if not could this be added?
Thank you and best regards
Peter
Tim Mooney wrote:
Peter,
EPICS 3.14.10 doesn't build libiocsh, as previous versions id.
You need to remove iocsh from the line
LIB_LIBS += stream dbIoc registryIoc iocsh
in srcSynApps/Makefile.
You'll still get iocsh, because base now has it in libCom.
Tim
Hi everybody,
when compiling streamDevice 2.4 from psi web page with CALC set in the
RELEASE file
I get the following output
base: 3.14.10, Debian 4.0
make[2]: Entering directory
`<EPICS_TOP>/modules/soft/StreamDevice/StreamDevice-2-4/srcSynApps/O.linux-x86'
Installing created dbd file ../../../dbd/streamSynApps.dbd
/usr/bin/gcc-3.4 -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500
-D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -m32 -g -fPIC
-I. -I../O.Common -I. -I.. -I../../../include/os/Linux
-I../../../include -I<EPICS_TOP>/modules/soft/seq/sncseq-2.0.12/include
-I<EPICS_TOP>/base-3.14.10/include/os/Linux
-I<EPICS_TOP>/base-3.14.10/include -I<EPICS_TOP>/modules/soft/asyn/asyn-4.10/include -I<EPICS_TOP>/modules/synApps/synApps_5_4_1/support/calc/2-7/include ../devscalcoutStream.c
/usr/bin/ar -rc   libstreamSynApps.a         devscalcoutStream.o
/usr/bin/ranlib libstreamSynApps.a
make[2]: *** No rule to make target
`../../../lib/linux-x86/libiocsh.a', needed by
`libstreamSynApps.so'. Stop.
make[2]: Leaving directory
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory
`<EPICS_TOP>/modules/soft/StreamDevice/StreamDevice-2-4/srcSynApps'
make: *** [srcSynApps.install] Error 2
without CALC set, everything compiles the right way.
and here the corresponding RELEASE
#RELEASE Location of external products
#If using the sequencer, point SNCSEQ at its top directory:
SNCSEQ=<EPICS_TOP>/modules/soft/seq/sncseq-2.0.12
# EPICS_BASE usually appears last so other apps can override stuff:
EPICS_BASE=<EPICS_TOP>/base
ASYN=<EPICS_TOP>/modules/soft/asyn/asyn-4.10
CALC=<EPICS_TOP>/modules/synApps/synApps_5_4_1/support/calc/2-7
PCRE_INCLUDE=/usr/include/pcre
PCRE_LIB=/usr/lib
Any help would be appreciated,
Peter
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
RE: compiling streamDevice with CALC set fails Mark Rivers
compiling streamDevice with CALC set fails Dr. Peter Zumbruch
Re: compiling streamDevice with CALC set fails Tim Mooney
Re: compiling streamDevice with CALC set fails Dr. Peter Zumbruch
Prev: macLib/msi changes with 3.14.10 Till Straumann
Next: Re: devLibOSD.c for Linux Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: devLib changes Davidsaver, Michael
Next: RE: compiling streamDevice with CALC set fails Mark Rivers
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
