Thank you,
doing so I got further but still failed at other places
But after changing
in addition
1) in the streamApp/Makefile
streamApp_DBD += calc.dbd
into
streamApp_DBD += calcSupport.dbd
and
2) added to the <TOP>/configure/RELEASE the line
SSCAN=<EPICS_TOP>/modules/synApps/synApps_5_4_1/support/sscan/2-6-4
I finally succeeded.
So I did the same what has been done for synApps.
Did I miss some part of documentation in relationship to EPICS 3.14.10
in StreamDevice docs about this
and if not could this be added?
Thank you and best regards
Peter
Tim Mooney wrote:
> Peter,
> EPICS 3.14.10 doesn't build libiocsh, as previous versions id.
> You need to remove iocsh from the line
> LIB_LIBS += stream dbIoc registryIoc iocsh
> in srcSynApps/Makefile.
> You'll still get iocsh, because base now has it in libCom.
> Tim
> Dr. Peter Zumbruch wrote:
>> Hi everybody,
>> when compiling streamDevice 2.4 from psi web page with CALC set in the
>> RELEASE file
>> I get the following output
>>> base: 3.14.10, Debian 4.0
>>> make[2]: Entering directory
>>> `<EPICS_TOP>/modules/soft/StreamDevice/StreamDevice-2-4/srcSynApps/O.linux-x86'
>>> Installing created dbd file ../../../dbd/streamSynApps.dbd
>>> /usr/bin/gcc-3.4 -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
>>> -D_XOPEN_SOURCE=500
>>> -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3
>>> -Wall -m32 -g -fPIC
>>> -I. -I../O.Common -I. -I.. -I../../../include/os/Linux
>>> -I../../../include
>>> -I<EPICS_TOP>/modules/soft/seq/sncseq-2.0.12/include
>>> -I<EPICS_TOP>/base-3.14.10/include/os/Linux
>>> -I<EPICS_TOP>/modules/soft/asyn/asyn-4.10/include
>>> -I<EPICS_TOP>/modules/synApps/synApps_5_4_1/support/calc/2-7/include
>>> ../devscalcoutStream.c
>>> /usr/bin/ar -rc libstreamSynApps.a devscalcoutStream.o
>>> /usr/bin/ranlib libstreamSynApps.a
>>> make[2]: *** No rule to make target
>>> `../../../lib/linux-x86/libiocsh.a', needed by
>>> `libstreamSynApps.so'. Stop.
>>> make[2]: Leaving directory
>>> make[1]: *** [install.linux-x86] Error 2
>>> make[1]: Leaving directory
>>> `<EPICS_TOP>/modules/soft/StreamDevice/StreamDevice-2-4/srcSynApps'
>>> make: *** [srcSynApps.install] Error 2
>> without CALC set, everything compiles the right way.
>> and here the corresponding RELEASE
>>> #RELEASE Location of external products
>>> #If using the sequencer, point SNCSEQ at its top directory:
>>> SNCSEQ=<EPICS_TOP>/modules/soft/seq/sncseq-2.0.12
>>> # EPICS_BASE usually appears last so other apps can override stuff:
>>> EPICS_BASE=<EPICS_TOP>/base
>>> ASYN=<EPICS_TOP>/modules/soft/asyn/asyn-4.10
>>> CALC=<EPICS_TOP>/modules/synApps/synApps_5_4_1/support/calc/2-7
>>> PCRE_INCLUDE=/usr/include/pcre
>>> PCRE_LIB=/usr/lib
>> Any help would be appreciated,
>> Peter
Dr. rer. nat. Peter W. Zumbruch
EE - department / Controls group / GSI
E-Mail: P.Zumbruch_at_gsi.de
Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführung: Professor Dr. Horst Stöcker, Christiane Neumann
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph,
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
- devLib changes Davidsaver, Michael
- Re: compiling streamDevice with CALC set fails Dirk Zimoch
- compiling streamDevice with CALC set fails Dr. Peter Zumbruch
- Re: compiling streamDevice with CALC set fails Tim Mooney
devLibOSD.c for Linux Mi Qingru
<2009>
<2009>
