Peter,
EPICS 3.14.10 doesn't build libiocsh, as previous versions id.
You need to remove iocsh from the line
LIB_LIBS += stream dbIoc registryIoc iocsh
in srcSynApps/Makefile.
You'll still get iocsh, because base now has it in libCom.
Tim
Dr. Peter Zumbruch wrote:
Hi everybody,
when compiling streamDevice 2.4 from psi web page with CALC set in the
RELEASE file
I get the following output
base: 3.14.10, Debian 4.0
make[2]: Entering directory
`<EPICS_TOP>/modules/soft/StreamDevice/StreamDevice-2-4/srcSynApps/O.linux-x86'
Installing created dbd file ../../../dbd/streamSynApps.dbd
/usr/bin/gcc-3.4 -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500
-D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3
-Wall -m32 -g -fPIC
-I. -I../O.Common -I. -I.. -I../../../include/os/Linux
-I../../../include
-I<EPICS_TOP>/modules/soft/seq/sncseq-2.0.12/include
-I<EPICS_TOP>/base-3.14.10/include/os/Linux
-I<EPICS_TOP>/modules/soft/asyn/asyn-4.10/include
-I<EPICS_TOP>/modules/synApps/synApps_5_4_1/support/calc/2-7/include
../devscalcoutStream.c
/usr/bin/ar -rc libstreamSynApps.a devscalcoutStream.o
/usr/bin/ranlib libstreamSynApps.a
make[2]: *** No rule to make target
`../../../lib/linux-x86/libiocsh.a', needed by `libstreamSynApps.so'.
Stop.
make[2]: Leaving directory
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory
`<EPICS_TOP>/modules/soft/StreamDevice/StreamDevice-2-4/srcSynApps'
make: *** [srcSynApps.install] Error 2
without CALC set, everything compiles the right way.
and here the corresponding RELEASE
#RELEASE Location of external products
#If using the sequencer, point SNCSEQ at its top directory:
SNCSEQ=<EPICS_TOP>/modules/soft/seq/sncseq-2.0.12
# EPICS_BASE usually appears last so other apps can override stuff:
EPICS_BASE=<EPICS_TOP>/base
ASYN=<EPICS_TOP>/modules/soft/asyn/asyn-4.10
CALC=<EPICS_TOP>/modules/synApps/synApps_5_4_1/support/calc/2-7
PCRE_INCLUDE=/usr/include/pcre
PCRE_LIB=/usr/lib
Any help would be appreciated,
Peter
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
- Re: compiling streamDevice with CALC set fails Dr. Peter Zumbruch
- compiling streamDevice with CALC set fails Dr. Peter Zumbruch
devLibOSD.c for Linux Mi Qingru
<2009>
<2009>
