Hi Larry,
On Tuesday 20 October 2009 05:46:13 Lawrence T. Hoff wrote:
> I just checked my MV3100 build environment for VxWorks
> 5.5.1. I use :
> ccppc -mcpu=8540 -msoft-float -mspe=no -mabi=no-spe -DCPU=PPC85XX ...
Thanks for those, I'll modify the CONFIG.Common.vxWorks-mpc8540 in Base to
match those flags. We have also been giving -mstrict-align -mlongcall for
the other PowerPC targets, which I will include with this target as well
unless you can confirm they are not needed.
William F. Steele wrote:
> I talked to WRS about this problem and was advised that I was using the
> wrong compiler. When I use Tornado to build vxWorks, Tornado uses
> /home/als2/devel/vxWorks/tornado2.2.1-ppc/host/gnu/3.3/sun4-
> solaris2/bin/ccppc, but when building EPICS, the EPICS build system uses
> /home/als2/devel/vxWorks/tornado2.2.1-ppc/host/sun4-solaris2/bin/ccppc,
> so, apparently, the EPICS build system does not automatically setup
> to use the correct tools when specifying the target
> vxWorks-mpc8540. What needs to be done to make this work right?
Very interesting, Wind River have upgraded the GCC compiler for the PowerPC
e500 family; that does make some sense. Unfortunately we don't have access to
the e500 family architecture on vxWorks here at APS which is why Base doesn't
build for it.
Please try editing your base/configure/os/CONFIG.Common.vxWorks-mpc8540 file
and add the following line (anywhere below the include line), which should
modify the build system to use the right compiler based on your paths above:
GNU_DIR_5 = $(WIND_BASE)/gnu/3.3/$(WIND_HOST_TYPE)
While you're at it, based on Larry's email I'm proposing the following
settings as well which I'd appreciate if you could try out in place of the
existing ones:
ARCH_DEP_CPPFLAGS = -DCPU=PPC85XX
ARCH_DEP_CFLAGS = -mcpu=8540 -msoft-float -mspe=no -mabi=no-spe
ARCH_DEP_CFLAGS += -mstrict-align -mlongcall
Please let me know whether all this works or if it needs tweaking.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- EPICS build for MVME3100 William F. Steele
- Re: EPICS build for MVME3100 Ron Sluiter
- RE: EPICS build for MVME3100 Lawrence T. Hoff
genSub and synApps 5_4_1 Emmanuel Mayssat
<2009>
procServ softIOC server - V2.4.1 released Ralph Lange
<2009>
