1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EPICS build for MVME3100
To: "Ron Sluiter" <[email protected]>, "William F. Steele" <[email protected]>
Cc: [email protected]
Date: Thu, 15 Oct 2009 08:21:19 -1000
Hi Ron and William,
I found this on the page Ron mentions:
Vxworks 5.5.1 BSP for MVME3100  Motorola MVME3100  Motorola, Inc.  Not
Supported  VxWorks: 5.5.1 - Tornado Tools 2.2.1 Freescale MPC85xx
WRS no longer supports the BSP, but it is available on their site for
download.
Erik
-----Original Message-----
[mailto:[email protected]] On Behalf Of Ron Sluiter
Sent: Thursday, October 15, 2009 7:01 AM
To: William F. Steele
Subject: Re: EPICS build for MVME3100
Hello William,
According to this WRS web page;
http://www.windriver.com/products/bsp_web/bsp_architecture.html?architec
ture=PowerPC
it does not look like the MVME3100 is supported with Tornado 2.2.1.
Ron
William F. Steele wrote:
> I don't understand how to build EPICS for MVME3100. I have no problem
> with mcp750, mvme2100, 68040,  or 68060. I am trying to build EPICS
> 3.14.11 and am using vxWorks 5.5.1 with Tornado 2.2.1. If I put
> vxWorks-mpc8540  in my list of CROSS_COMPILER_TARGET_ARCHS, I get
> compile errors which I traced to ARCH_DEP_CPPFLAGS which is set to
> -DCPU=PPC32 which the compiler does not recognize. If I change that to
> ARCH_DEP_CPPFLAGS = -DCPU=PPC85XX, then I no longer get compile
> errors, but EPICS will not load due to a lot of undefined symbols. I
> talked to WRS about this problem and was advised that I was using the
> wrong compiler. When I use Tornado to build vxWorks, Tornado uses
> /home/als2/devel/vxWorks/tornado2.2.1-ppc/host/gnu/3.3/sun4-solaris2/b
> in/ccppc, but when building EPICS, the EPICS build system uses
> /home/als2/devel/vxWorks/tornado2.2.1-ppc/host/sun4-solaris2/bin/ccppc
> , so, apparently, the EPICS build system does not automatically setup
> to use the correct tools when specifying the target vxWorks-mpc8540.
> What needs to be done to make this work right? Thanks.
EPICS build for MVME3100 William F. Steele
Re: EPICS build for MVME3100 Ron Sluiter
Prev: Re: EPICS build for MVME3100 Ron Sluiter
Next: StripTool build errors: SDDS.h? Carl Schumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: EPICS build for MVME3100 Lawrence T. Hoff
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
