Hi Andrew
On Mittwoch, 7. Oktober 2009, Andrew Johnson wrote:
> On Monday 05 October 2009 15:54:33 Benjamin Franksen wrote:
> > On Montag, 5. Oktober 2009, Andrew Johnson wrote:
> > > I agree with Michael in favor of changing the behavior so that when a
> > > client specifies COUNT=0 in its subscription, it is requesting a
> > > dynamic element count such that successive events may have different
> > > numbers of elements. However it should never be given more than
> > > ca_element_count() elements so it can always use that number to
> > > allocate data storage at connection time. If at some time in the
> > > future we want to make it possible for even that number to be
> > > increased, this could be indicated to the client by a pair of
> > > disconnect/ reconnect events.
> > I would be very happy if something like this could be done at the
> > database level i.e. for pv links between records.
> I agree we should implement this for PV links,
Excellent!
> but I don't want to break
> applications that might rely on the existing behavior
Sure.
> (can you remember
> what happens right now, do both DB and CA links zero-fill the elements
> beyond the current element count?).
I dimly remember I have gotten garbage in some tests when I erroneously
assumed that dynamic sizing would 'just work' but I can't remember the
details.
Thanks
Ben
- Channel access and ca_element_count michael.abbott
- Re: Channel access and ca_element_count Benjamin Franksen
- Re: Channel access and ca_element_count Andrew Johnson
Re: Basler scA1000-30gm Camera Jens . Eden
<2009>
Re: EPICS Python client application survey Matt Newville
<2009>
