Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: state notation code flags
From: Benjamin Franksen <benjamin.franksen@bessy.de>
To: tech-talk@aps.anl.gov
Date: Mon, 5 Oct 2009 22:47:18 +0200
On Montag, 5. Oktober 2009, Andrew Johnson wrote:
> I suspect it would be a good idea to try and get the the SNL compiler to
> issue a warning whenever it sees someone calling pvPut() on a variable
> which has a monitor on it, since this is IMHO an unsafe practice.
It is not if you do it right. I have never observed any problems with it.
You just have to make sure that the value your SNL program writes is
different from what the outside writes. Typically I reserve some value
(usually 0) for 'done' (a.k.a. 'idle'). The outside is not allowed to write
this value (this can be enforced using yet another record). Then I have
some SNL code like
int cmd;
assign cmd to "whatever";
monitor cmd;
state idle {
    when (cmd==DO_SOMETHING) {
        setup_execution();
    } state first_intermediate_state
    when () {
    } state done
...intermediate states...
state done {
    when ... {
        cmd = 0;
        pvPut(cmd);
    } state idle
The advantage is that I don't need event flags which I always found to be
unreliable.
Cheers
Ben
Re: state notation code flags Benjamin Franksen
state notation code flags Patrick Thomas
RE: state notation code flags Mark Rivers
Re: state notation code flags Andrew Johnson
Prev: Re: EPICS Python client application survey Matt Newville
Next: Re: Channel access and ca_element_count Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
Prev: RE: state notation code flags Mark Rivers
Next: Re: state notation code flags Benjamin Franksen
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
