1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: state notation code flags
Cc: [email protected]
Date: Mon, 5 Oct 2009 11:16:50 -0500
Hi Mark,
On Monday 05 October 2009 10:32:12 Mark Rivers wrote:
> Either I don't understand your analysis, or I don't agree with it.
> Your suggestion is:
> int abort;
> int abortOut;
> assign abort to "{P}{R}Abort.VAL";
> assign abortOut to "{P}{R}Abort.VAL";
> monitor abort;
> evflag abortMon;
> sync abort abortMon;
> ss xpsTrajectoryAbort {
>     state monitorAbort {
>         when (efTestAndClear(abortMon) &&
>               (execState==EXECUTE_STATE_EXECUTING)) {
>             abortOut=0;
>             pvPut(abortOut);
>         } state monitorAbort
> Consider what happens when an external agent sets Abort.VAL to 1.
> The when statement will detect the monitor event, set abortOut=0 and
> call pvPut.  That will result in another monitor event, and the when
> statement will execute a second time, again setting abortOut=0 and doing
> the pvPut.  In fact this can potentially cause an infinite loop, but
> normally won't because records won't call dbPostEvents if the value has
> not changed?
> This double-processing is what Patrick is trying to avoid.  It can be
> avoided by detecting that the monitor callback is for the same value
> that was written with the previous pvPut, or by using Tim's database
> logic.
My impression was that Patrick was seeing the event flag being set *twice* by
an update that his put caused, which I didn't think was quite the same thing
that you described.  I admit I didn't look at your example very closely and
you're right that in your particular case you would want to keep the test of
the abort variable in the when condition.  Patrick certainly needs to make
sure that his sequence program can handle the reflections caused by its own
put operations.
However I don't think this invalidates my main point, which is that using the
same variable for both monitoring a PV and putting values to it is open to
strange things happening due to a possible race condition.  I suspect that's
why you saw a difference in behavior between R3.13 and R3.14.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
RE: state notation code flags Mark Rivers
state notation code flags Patrick Thomas
Re: state notation code flags Andrew Johnson
Prev: RE: Channel access dynamic array subscription update element count Jeff Hill
Next: Re: Channel access dynamic array subscription update element count Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: state notation code flags Mark Rivers
Next: RE: state notation code flags Mark Rivers
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
