Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
Subject: RE: state notation code flags
To: "Patrick Thomas" <thomas_p@ligo-wa.caltech.edu>
Cc: tech-talk@aps.anl.gov
Date: Fri, 2 Oct 2009 22:27:12 -0500
OK, I was not aware that doing a pvGet on a PV that you have set a monitor and event flag on would set the event flag.  But you normally would never do this: if you set a monitor on a PV then you don't ever need to do a pvGet on it; the variable is guaranteed to always contain the most recent value of that PV without ever calling pvGet.
From: Patrick Thomas [mailto:thomas_p@ligo-wa.caltech.edu]
Sent: Fri 10/2/2009 7:29 PM
To: Mark Rivers
Subject: Re: state notation code flags
This also prints out the flag:
program sncTest
float test_put;
assign test_put to "H3:TEST_PUT";
monitor test_put;
evflag test_putEvent;
sync test_put test_putEvent;
float test_get;
assign test_get to "H3:TEST_GET";
monitor test_get;
evflag test_getEvent;
sync test_get test_getEvent;
ss ss1 {
        state init {
                when () {
                        efClear(test_getEvent);
                        pvGet(test_get);
                        if (efTest(test_getEvent)) {
                                printf("flag set\n");
                } state wait
                when () {
                        efClear(test_putEvent);
                        test_put = 40;
                        pvPut(test_put, SYNC);
                } state wait
        state wait {
                when () {
                        if (efTest(test_putEvent)) {
                } state wait
                when () {
                } state wait
Mark Rivers wrote:
> Patrick,
> pvGet will not set the event flag.  Event flags are only set on monitor
> callbacks, i.e. when the value changes in the IOC and it does callbacks
> to channel access clients that have subscribed to that channel.
> pvGet(pv) normally blocks for the operation to complete, so it gives the
> same behavior as pvGet(pv, SYNC) (unless you compiled with the +a
> option, which I would not recommend).
> pvPut(pv) and pvPut(pv, SYNC) do behave differently, because the default
> behavior is not to wait for the pvPut to complete, adding the SYNC
> option forces it to wait for the put to complete.
> Mark
> -----Original Message-----
> Sent: Friday, October 02, 2009 1:25 PM
> To: Mark Rivers
> Hi Mark,
> If I have the following:
> float request_move_to_absolute_position;
> assign request_move_to_absolute_position to
> "{IFO}:{DRIVER}_REQUEST_MOVE_TO_ABS_POS_{AXIS}";
> monitor request_move_to_absolute_position;
> evflag request_move_to_absolute_positionEvent;
> sync request_move_to_absolute_position
> pvGet(request_move_to_absolute_position);
> efClear(request_move_to_absolute_positionEvent);
> Will the pvGet set the request_move_to_absolute_positionEvent flag? If
> so, is it possible that even with the efClear, the flag will remain set
> at the end of the code, because the pvGet will not have completed before
> the efClear is encountered? But if
> pvGet(request_move_to_absolute_position, SYNC) is used, will this
> guarantee that the efClear will clear the flag?
> Thank you,
> Patrick
> Mark Rivers wrote:
>> Patrick,
>> Event flags can be explicitly set, which is typically used to allow
>> communication between state sets.  Or event flags can be synced to a
> PV,
>> and will be set whenever a monitor is received for that PV, as in the
>> example I sent you.
>> You can use the efTest() function outside of a when statement, just
> like
>> any other function.
>> Mark
>> Sent: Thursday, October 01, 2009 5:20 PM
>> To: Mark Rivers
>> Hi Mark,
>> Are the flags on a monitored variable set whenever the monitored
>> variable is used in the code, including a pvPut, pvGet, assignment,
>> calculation, or print statement? Is there a way to test if the flag is
>> set besides an efTest in a when statement?
>> Thank you,
>> Patrick
>> Mark Rivers wrote:
>>> Hio Patrick,
>>> Here are some code snippets from one of my SNL programs.  It has a
>> variable nelements assigned to a PV, and a monitor on that PV.  It has
>> an event flag, nelementsMon that is synced to nelements.  Whenever
>> nelements changes the event flag will be set.  In the init state I
> clear
>> the event flag, just to be sure it is clear when the SNL code starts
>> running (after all PVs connect).  I then use efTestAndClear in a when
>> statement to take actions when that event flag is set, and to clear
> it.
>> This works fine for me.
>>> int     nelements;   assign nelements    to "{P}{R}Nelements.VAL";
>>> monitor nelements;
>>> evflag nelementsMon;    sync nelements  nelementsMon;
>>>     /* Initialize things when first starting */
>>>     state init {
>>>         when() {
>>>             /* Clear all event flags */
>>>             efClear(nelementsMon);
>>>         } state monitor_inputs
>>>     state monitor_inputs {
>>>         when(efTestAndClear(nelementsMon) && (nelements>=1)) {
>>>             /* If nelements changes, then change endPulses to this
>> value,
>>>              * since this is what the user normally wants.  endPulses
>> can be
>>>              * changed again after changing nelements if this is
>> desired. */
>>>             if (moveMode == MOVE_MODE_RELATIVE)
>>>                 endPulses = nelements;
>>>             else
>>>                 endPulses = nelements-1;
>>>             pvPut(endPulses);
>>> Mark
>>> ________________________________
>>> From: tech-talk-bounces@aps.anl.gov on behalf of Patrick Thomas
>>> Sent: Wed 9/30/2009 10:35 PM
>>> To: tech-talk@aps.anl.gov
>>> Subject: state notation code flags
>>> Hi,
>>> I was wondering if there is a way to track at what point in the state
>>> notation code evflags are getting set and cleared, or if someone
> could
>>> clarify under what conditions they get set. I'm having trouble with
>> them
>>> getting set somewhere and not being cleared, but I'm not sure where.
>>> Thank you,
>>> Patrick
state notation code flags Patrick Thomas
RE: state notation code flags Mark Rivers
Re: state notation code flags Patrick Thomas
Prev: RE: state notation code flags Mark Rivers
Next: Re: state notation code flags Patrick Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
Prev: Re: state notation code flags Patrick Thomas
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
