Hello,
I hope you are all doing well.
I may have asked this question a months ago, but ...
I have the following DB processing scheme
AO (high level PV name) --> AO ( hardware PV name) ---> hardware ---> AI
(hardware PV name) --> AI (high level PV name)
When I set the first AO, the value is propagated to the other one (on
OUT field), then to the hardware and finally read back on both of the AI.
The issue is that when I reboot the IOC, the first AO is reset to 0.
Ultimately I would like it to be set at current value (read hardware
first and then set value accordingly).
With AI with a PINI=YES, I can see what the hardware value in both AI.
How can I load the CURRENT hardware value in the 1st AO at init?
( I use base < 3.14.11, so not so easy to use multilayer aliasing!!)
Additionally could someone give an example where the DOL + OMSL field
are commonly used?
I wonder what the practical purposes of those fields are.
Emmanuel
- Re: propagating value upward at init Liu, Gongfa
- Re: propagating value upward at init Dirk Zimoch
RE: state notation code flags Mark Rivers
<2009>
Re: state notation code flags Benjamin Franksen
<2009>
