1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Python client application survey
To: [email protected]
Date: Thu, 1 Oct 2009 15:03:54 +0200
On Thursday 01 October 2009, Michael Abbott wrote:
> On Wed, 30 Sep 2009, Andrew Johnson wrote:
> >  * DBE_PROPERTY events.  Generated now on the VAL field of the mbb[io]
> > record types when someone changes one of the *ST fields, a DBE_PROPERTY
> > monitor allows a client to always know what the current ENUM strings
> > are.
> I guess that's easy enough: presumably if the DBE_PROPERTY bit is set in
> a CA request to a pre .14.11 server it'll have no effect,
I'd think so.
> so I guess I
> can just add DBE_PROPERTY to my list of event types.
The idea is that you can set up two monitors: one with a simple DBR_ENUM (or
DBR_ST_ENUM or DBR_TIME_ENUM) for frequent value and/or status changes
(DBE_VALUE|DBE_STATUS); and another one with the full DBR_CTRL_ENUM for the
(hopefully) very infrequent changes of the enumeration strings (requesting
/only/ events of type only DBE_PROPERTY). Which means you save network
bandwidth and IOC cpu load as compared to only one monitor requesting
DBR_CTRL_ENUM for all event types.
Cheers
Ben
Re: EPICS Python client application survey Andrew Johnson
Re: EPICS Python client application survey Michael Abbott
Prev: RE: state notation code flags Mark Rivers
Next: Re: EPICS Python client application survey Michael Abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS Python client application survey Michael Abbott
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
