1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Python client application survey
To: Matt Newville <[email protected]>
Cc: [email protected], John Hammonds <[email protected]>, [email protected], [email protected]
Date: Wed, 30 Sep 2009 12:49:56 -0500
Matt Newville wrote:
Hi Noboru, Wang, John, Michael, all,
As I've said before, I would be happy to collaborate to come up with a
more uniform approach to using CA with Python.
I agree with Noboru that a two-tier approach is needed.  I'm not so
sure that a 'thin wrapper to all of ca' is crucial.
I also agree with Noboru, and with most of your reply.  However, I'm in
favor of a 'thin wrapper to all of ca', at least as a one part of the
interface.  One reason is that I don't know all of the things I might
ever have to do with Python/CA, and I wouldn't want to invest effort
learning, and building a code base around, an interface that might run
out of gas when I need to do something that wasn't anticipated.
For example, I don't see significant advantages to having all the C CA
types (DBR_SHORT, DBR_INT, DBR_LONG, etc) exposed to Python at all, as
Python does not distinguish these types, and the difference never
needs to be exposed to the Python programmer.
I wouldn't want to say "never".  If the data are going to end up in
Python variables, I'd agree that DBR_SHORT and DBR_INT, for example,
are unnecessary complications.  But if I had to read a very large
array of two-byte integers, and hand the array off to some other
code that expects an array of two-byte integers, I would need at
minimum some way of specifying that two-byte integers be sent.
--Matt Newville <newville at cars.uchicago.edu>
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Re: EPICS Python client application survey Matt Newville
Prev: Re: EPICS Python client application survey Matt Newville
Next: Re: EPICS Python client application survey Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS Python client application survey Andrew Johnson
Next: Re: EPICS Python client application survey Matt Newville
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
