1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: alarm handler on base 3-14-11
To: [email protected]
Date: Mon, 28 Sep 2009 14:42:35 -0500
On Monday 28 September 2009 03:56:32 Dirk Zimoch wrote:
> Why are there always such unnecessary incompatibilities in new versions of
> EPICS? Life would be so much easier if working EPICS software could
> continue to work with later versions (at least of with same major/minor
> release).
EPICS Base is Open Source software, we make it available to anyone without
charge and welcome help with its development.  The best way to improve the
quality of the releases would be to get involved with testing the pre-release
versions and suggest modifications or patches before the final releases are
made.  Think of the effort required as a Software Maintenance Contract payment
to the core development project; it's much cheaper than maintaining it all by
yourself.
The source code changes required to build with 3-14-11 are compatible with
earlier 3-14 versions of Base, once you've made them your code should still
build with previous versions.  Personally I regard minor source code fixes
like these as occasionally necessary to improve software quality overall.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
alarm handler on base 3-14-11 Patrick Thomas
RE: alarm handler on base 3-14-11 Mark Rivers
Re: alarm handler on base 3-14-11 Dirk Zimoch
Prev: Re: alarm handler on base 3-14-11 Dirk Zimoch
Next: EPICS Python client application survey Abbott, Michael (DLSLtd,RAL,DIA)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: alarm handler on base 3-14-11 John William Sinclair
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
