1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: alarm handler on base 3-14-11
Cc: [email protected]
Date: Wed, 23 Sep 2009 19:38:03 -0700
I do see though that the 3-14-10 version seems to use libcurses and 3-14-11 uses libncurses. What is the difference between these?
Mark Rivers wrote:
I think that is the 32-bit version, and you need the 64-bit version, which will be in usr/lib64
From: [email protected] on behalf of Patrick Thomas
Sent: Wed 9/23/2009 9:02 PM
To: Zhichu Chen
I think it is installed, there is a libncurses.so.5 file in /usr/lib.
Zhichu Chen wrote:
Install ncurses library by yourself.
On Thu, Sep 24, 2009 at 9:47 AM, Patrick Thomas
<[email protected]> wrote:
Thank you, that seems to have worked. However, now it errors on 'cannot find
-lncurses' for g++ -o alh.
Mark Rivers wrote:
This is a common change required in 3.14.11.
 You need to "#include menuYesNo.h" and YES needs to be changed to
menuYesNoYES.
Sent: Wed 9/23/2009 8:00 PM
To: [email protected]
Subject: alarm handler on base 3-14-11
I was wondering, I get a compile error on force.c when running make on
the alarm handler with epics-3-14-11, on 64 bit linux:
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux
 -D_REENTRANT   -O3   -Wall      -m64     -g  -I. -I../O.Common -I.
-I../os/default -I.. -I../../../include/os/Linux -I../../../include
-I/users/thomas/epics/base/base-3-14-11/include/os/Linux
-I/users/thomas/epics/base/base-3-14-11/include         -I../os/Linux
-I../os/default -I/usr/include -I/usr/include/X11    ../force.c
../force.c: In function 'forcePVUpdateFields':
../force.c:1028: error: 'YES' undeclared (first use in this function)
../force.c:1028: error: (Each undeclared identifier is reported only once
../force.c:1028: error: for each function it appears in.)
make[2]: *** [force.o] Error 1
make[2]: Leaving directory
`/users/thomas/epics/extensions/src/alh1_2_24/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/users/thomas/epics/extensions/src/alh1_2_24'
make: *** [alh1_2_24.install] Error 2
Thank you,
Patrick
Re: alarm handler on base 3-14-11 Matthieu Bec
alarm handler on base 3-14-11 Patrick Thomas
RE: alarm handler on base 3-14-11 Mark Rivers
Re: alarm handler on base 3-14-11 Patrick Thomas
Re: alarm handler on base 3-14-11 Zhichu Chen
Prev: Re: alarm handler on base 3-14-11 Patrick Thomas
Next: Re: alarm handler on base 3-14-11 Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: alarm handler on base 3-14-11 Thomas Birke
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
