Hi Patrick,
Sorry, I missed one change that I made for 3.14.11 when I diff the CVS diff. Here it is:
Index: StreamDevice-2-4/src/devwaveformStream.c
RCS file: /net/beams-nfs/export/local/cvs/support/stream/StreamDevice-2-4/src/devwaveformStream.c,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -r1.1 -r1.2
--- StreamDevice-2-4/src/devwaveformStream.c 2008/11/24 18:07:33 1.1
+++ StreamDevice-2-4/src/devwaveformStream.c 2009/08/28 23:42:17 1.2
@@ -19,6 +19,7 @@
#include "devStream.h"
+#include <errlog.h>
#include <waveformRecord.h>
#include <string.h>
#include <epicsExport.h>
Needing to include "errlog.h" in code that previously did not include it is one of the most common changes needed when upgrading to 3.14.11.
For completeness I am appending all changes I've made from 2-4 to fix errors and compiler warnings when building on 64-bits.
corvette:~/devel/stream/2-4>cvs diff -rR2-4
? configure/RELEASE.win32-x86-debug
cvs server: tag R2-4 is not in file .cvsignore
Index: StreamDevice-2-4/src/AsynDriverInterface.cc
RCS file: /net/beams-nfs/export/local/cvs/support/stream/StreamDevice-2-4/src/AsynDriverInterface.cc,v
diff -u -r1.1 -r1.2
--- StreamDevice-2-4/src/AsynDriverInterface.cc 2008/11/24 18:07:33 1.1
+++ StreamDevice-2-4/src/AsynDriverInterface.cc 2009/09/01 18:40:37 1.2
@@ -129,9 +129,11 @@
"asynSuccess", "asynTimeout", "asynOverflow", "asynError"
+#ifndef NO_TEMPORARY
static const char* eomReasonStr[] = {
"NONE", "CNT", "EOS", "CNT+EOS", "END", "CNT+END", "EOS+END", "CNT+EOS+END"
+#endif
class AsynDriverInterface : StreamBusInterface
#ifdef EPICS_3_14
@@ -663,6 +665,16 @@
clientName(), pasynUser->errorMessage);
writeCallback(StreamIoFault);
return;
+ case asynDisconnected:
+ error("%s: asynDisconnected in write: %s\n",
+ clientName(), pasynUser->errorMessage);
+ writeCallback(StreamIoFault);
+ return;
+ case asynDisabled:
+ error("%s: asynDisabled in write: %s\n",
+ return;
@@ -922,6 +934,15 @@
readCallback(StreamIoFault, buffer, received);
break;
+ error("%s: asynDisconnected in read: %s\n",
+ readCallback(StreamIoFault, buffer, received);
+ return;
+ error("%s: asynDisabled in read: %s\n",
if (!readMore) break;
if (readMore > 0)
Index: StreamDevice-2-4/src/ChecksumConverter.cc
RCS file: /net/beams-nfs/export/local/cvs/support/stream/StreamDevice-2-4/src/ChecksumConverter.cc,v
diff -u -r1.1 -r1.2
--- StreamDevice-2-4/src/ChecksumConverter.cc 2008/11/24 18:07:33 1.1
+++ StreamDevice-2-4/src/ChecksumConverter.cc 2009/09/01 18:41:28 1.2
@@ -542,9 +542,9 @@
debug("ChecksumConverter %s: output to check: \"%s\"\n",
checksumMap[fnum].name, output.expand(start,length)());
- sum = checksumMap[fnum].xorout ^ checksumMap[fnum].func(
+ sum = checksumMap[fnum].xorout ^ (checksumMap[fnum].func(
reinterpret_cast<uchar*>(output(start)), length,
- checksumMap[fnum].init) & mask[checksumMap[fnum].bytes];
+ checksumMap[fnum].init) & mask[checksumMap[fnum].bytes]);
debug("ChecksumConverter %s: output checksum is 0x%lX\n",
checksumMap[fnum].name, sum);
@@ -603,9 +603,9 @@
return -1;
reinterpret_cast<uchar*>(input(start)), length,
debug("ChecksumConverter %s: input checksum is 0x%0*lX\n",
checksumMap[fnum].name, 2*checksumMap[fnum].bytes, sum);
diff -u -r1.1 -r1.2
@@ -19,6 +19,7 @@
#include <string.h>
Index: configure/RELEASE
RCS file: /net/beams-nfs/export/local/cvs/support/stream/configure/RELEASE,v
retrieving revision 1.3
diff -u -r1.3 RELEASE
--- configure/RELEASE 2008/10/24 19:36:49 1.3
+++ configure/RELEASE 2009/09/23 04:39:45
@@ -9,11 +9,11 @@
# module defined in the RELEASE file is rebuilt.
SUPPORT=/corvette/home/epics/devel
-ASYN=/corvette/home/epics/devel/asyn/4-10
-CALC=/corvette/home/epics/devel/calc/2-6-5beta
-SSCAN=/corvette/home/epics/devel/sscan/2-6-2
+ASYN=/corvette/home/epics/devel/asyn/4-13
+CALC=/corvette/home/epics/devel/calc/2-8
+SSCAN=/corvette/home/epics/devel/sscan/2-6-6
# EPICS_BASE usually appears last so other apps can override stuff:
-EPICS_BASE=/corvette/usr/local/epics/base-3.14.10
+EPICS_BASE=/corvette/usr/local/epics/base-3.14.11
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
Index: configure/RELEASE.win32-x86
RCS file: /net/beams-nfs/export/local/cvs/support/stream/configure/RELEASE.win32-x86,v
diff -u -r1.3 RELEASE.win32-x86
--- configure/RELEASE.win32-x86 2008/10/24 19:36:49 1.3
+++ configure/RELEASE.win32-x86 2009/09/23 04:39:45
@@ -9,10 +9,10 @@
SUPPORT=J:/epics/devel
-ASYN=J:/epics/devel/asyn/4-10
-CALC=J:/epics/devel/calc/2-6-5beta
-SSCAN=J:/epics/devel/sscan/2-6-2
+ASYN=J:/epics/devel/asyn/4-13
+CALC=J:/epics/devel/calc/2-8
+SSCAN=J:/epics/devel/sscan/2-6-6
-EPICS_BASE=H:/epics/base-3.14.10
+EPICS_BASE=H:/epics/base-3.14.11
Sent: Tue 9/22/2009 11:30 PM
To: Mark Rivers
Cc: [email protected]
Subject: Re: building streamdevice with epics 3.14.11
Sorry, forgot to cc this to tech-talk.
I am also using 2-4, on linux-x86-64.
I get the following error:
make -C ./src install make[1]: Entering directory
`/users/thomas/test/modules/StreamDevice/StreamDevice-2-4/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[2]: Entering directory
`/users/thomas/test/modules/StreamDevice/StreamDevice-2-4/src/O.linux-x86_64'
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT
-O3 -Wall -m64 -g -fPIC -I. -I../O.Common -I. -I..
-I../../../include/os/Linux -I../../../include
-I/users/thomas/test/modules/sncseq-2.0.12/include
-I/users/thomas/test/modules/asyn-4.12/include
-I/users/thomas/test/base/base-3-14-11/include/os/Linux
-I/users/thomas/test/base/base-3-14-11/include ../devwaveformStream.c
../devwaveformStream.c: In function 'readData':
../devwaveformStream.c:52: warning: implicit declaration of function
'errlogSevPrintf'
../devwaveformStream.c:52: error: 'errlogFatal' undeclared (first use in
this function)
../devwaveformStream.c:52: error: (Each undeclared identifier is
reported only once
../devwaveformStream.c:52: error: for each function it appears in.)
../devwaveformStream.c:132: error: 'errlogMajor' undeclared (first use
in this function)
../devwaveformStream.c: In function 'writeData':
../devwaveformStream.c:184: error: 'errlogFatal' undeclared (first use
in this function)
make[2]: *** [devwaveformStream.o] Error 1
make[2]: Leaving directory
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory
make: *** [src.install] Error 2
Thank you,
Patrick
Mark Rivers wrote:
> I have built streamDevice 2-4 with 3.14.11 with no problems. This is the version of streamDevice in the synApps module, but I think the code for devwaveformStream.c should be the same. What version of streamDevice are you using, on what platform, and what is the error?
> Mark
> ________________________________
> From: [email protected] on behalf of Patrick Thomas
> Sent: Tue 9/22/2009 10:44 PM
> To: [email protected]
> Subject: building streamdevice with epics 3.14.11
> Hi,
> Has anyone else had any trouble building the stream device module with
> epics base 3-14-11? I seem to get compile errors on running make with
> reference to ../devwaveformStream.c
> Thank you,
> Patrick
- Re: building streamdevice with epics 3.14.11 Patrick Thomas
- building streamdevice with epics 3.14.11 Patrick Thomas
- RE: building streamdevice with epics 3.14.11 Mark Rivers
<2009>
<2009>
