At Jefferson Lab, we have been using the dump the output of the "dbl"
command to a file in the st.cmd files method to initialize the CA
nameserver. Recently, however, it was requested to make sure the dbl
command was before the iocInit. But in doing so I find the
the dbl command does not complete its dump to the redirected file but is
interrupted in the process and dumps some of the file to
standard out. (I can see it in the iocsh.) The following line is in all
our ioc st.cmd files:
< O_prod/epics/startup.epicsgo
in epics 3.13 startup.epicsgo, always worked:
# Start EPICS
cd HOME
<../getBoot.vx
dbl > signal.list
symLkupPgSz=0
lkup "_loaded" > app.list
symLkupPgSz=22
iocInit "resource.def"
in epics 3.14.8.2 startup.epicsgo, DOES NOT work:
# Start EPICS
<resource.def
dbl > signal.list
symLkupPgSz=0
symLkupPgSz=22
iocInit
in epics 3.14.8.2 startup.epicsgo, works:
# Start EPICS
<resource.def
symLkupPgSz=0
symLkupPgSz=22
iocInit
dbl > signal.list
Is there an obvious explanation for this behavior? I'm running epics
3.14.8.2, vxWorks 5.5 on mv2700 and mv5100.
Thanks in advance for any insight.
Sue Witherspoon
Accelerator Software Controls
Jefferson Lab
757-269-7579
- Spring Meeting 2010? Mathias Steiner
Re: Getting String Form of Enums Kasemir, Kay
makeBaseApp -t ioc missing Makefile Patrick Thomas
<2009>
<2009>
