Hi all,
I'm having a terminology issue someone might help with, because the
comments posted on this thread appear to mix 'record' and 'PV'
terminology interchangeably. Most of the time it's clear, and although
there is a reasonable '1 to n' relation between the two, I can think of
example that relation can break. To give an example, say:
ioc1 uses old xxx record type, that does not have .YYY field
ioc2 uses new xxx record type, that has a new .YYY field
xxx 'record' (dbl/dbgrep etc) report the same thing.
but ioc2 use a newer version that might add/remove some fields (that I
think is what we really call PV = I think of it as the entity you get
over channel access)
So what does pvCrawl really look at: PVs or records? does it figure in
my example field .YYY exists in ioc2 but not ioc1?
Thanks
Matthieu
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- Re: list all process variables, linux alarm handler Don Dohan
- list all process variables, linux alarm handler Patrick Thomas
- Re: list all process variables, linux alarm handler Brian Bevins
Re: MBBO Record Initialization Maren Purves
<2009>
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
