Hi Maurizio,
there's not much you can do inside the stringin record - it will post a
value whenever it gets processed and the string changes.
The CA Archiver keeps a ring buffer for each channel, where values are
stored until the buffer is flushed out to disk.
The "buffer overwrite" will occur usually on monitored channels, if
values are coming in with a much higher rate than the archiver
configuration declares. You have to adjust the archiver configuration:
- Start a command line camonitor on the channel to see how fast the
updates are.
- Set the <period> for the channel to something that gets
close to the real update rate.
- If update rates are changing a lot: Increase the
<buffer_reserve> for a higher safety margin.
Good luck!
Ralph
Maurizio Montis wrote:
i have an IOC connectied with an High Current Power Supply and i use
StringIn/StringOut records to comunicate with it. I also have an EPICS
Archiver that archives any PV in my Channel Access, but i have a
"buffer over-write" problem with the StringIn record. If i have Ai
records i know i have to set ADEL and MDEL fields, but i would like to
know if i can do the same with my StringIn and/or how i have to set my
record to solve this problem.
Thanks a lot!
Maurizio M.
- "buffer over-write" problem with StringIn record Maurizio Montis
RE: sequencer feature request Mark Rivers
RE: Recommendation for digitizer? Szalata, Zenon M.
<2009>
StreamDevice Pierrick Hanlet
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
