Sorry, I still think I am right !
I run my tests on a soft Linux IOC. The asDumpRules cmd seems to be
asprules in my case. Here are my results with A=1 and A=2 following
Andrew’s suggestion (A& … instead of A >> …).
With A=1 the 1rst RULE for WRITE is TRUE which is OK
With A=2 I A&2 = 2 which is NOT the TRUE value (TRUE corresponds to 1
and not to !=0):
Simulateur >
Simulateur >*dbpf ASGVAL,1*
DBR_LONG: 1 0x1
Simulateur >asprules
ASG(DEFAULT) {
INPA(ASGVAL) value=1.000000
RULE(1,READ,NOTRAPWRITE)
* RULE(1,WRITE,NOTRAPWRITE) {*
* UAG(tous)*
* HAG(hag)*
* CALC("A&1") result=TRUE* **
UAG(develop)
HAG(hag)
CALC("A&2") result=FALSE
UAG(physique)
HAG(hag)
CALC("A&4") result=FALSE
UAG(gournay)
HAG(hag)
CALC("A&8") result=FALSE
UAG(epics)
HAG(hag)
CALC("A&16") result=FALSE
Simulateur >*dbpf ASGVAL,2*
DBR_LONG: 2 0x2
ASG(DEFAULT) {
INPA(ASGVAL) value=2.000000
UAG(tous)
HAG(hag)
CALC("A&1") result=FALSE
* UAG(develop)*
* HAG(hag)*
* CALC("A&2") result=FALSE*
UAG(physique)
HAG(hag)
UAG(gournay)
HAG(hag)
UAG(epics)
HAG(hag)
Simulateur >
If now I change the 2nd rule from A&2 to A>>1, I have now TRUE:
DBR_LONG: 2 0x2
ASG(DEFAULT) {
UAG(tous)
HAG(hag)
*RULE(1,WRITE,NOTRAPWRITE) {*
* UAG(develop)*
* HAG(hag)*
* CALC("A>>1") result=TRUE*
UAG(physique)
HAG(hag)
UAG(gournay)
HAG(hag)
UAG(epics)
HAG(hag)
J.F. Gournay
CEA Saclay
IRFU/SIS
-----Message d'origine-----
De : Martin L. Smith [mailto:[email protected]]
Envoyé : jeudi 10 septembre 2009 12:50
À : GOURNAY Jean-Francois
Cc : [email protected]
Objet : Re: Access security problem
Actually Andrew is correct. Take the "A&2" as an example, when bit 1 is TRUE
then the result of the CALC is TRUE, when bit 1 is FALSE then the result of
the CALC will be FALSE. TRUE being = 1 and FALSE being = 0.
This may be why you are seeing this problem. If you log into the IOC console
and issue this command you will see the value that CA access security thinks
your CALC expression evaluates to as shown below.
asDumpRules
ASG(ID01ds_ACTION) {
INPA(ID01ds:AccessSecurity) value=3.000000
RULE(0,WRITE,TRAPWRITE) {
UAG(operator)
HAG(local)
CALC("A<3") result=FALSE
UAG(flcord)
HAG(flctrl,local)
CALC("A<2") result=FALSE
RULE(1,WRITE,TRAPWRITE) {
UAG(sec01)
HAG(sec01)
CALC("A<1") result=FALSE
UAG(appdev)
Marty
GOURNAY Jean-Francois wrote:
Dear Andrew,
I think you are wrong. Remember that the CALC expression must return
TRUE or FALSE which will not be the case with A&2, A&4 ...
I guess my scheme is correct. Everything works except this problem
with this spiral2mgr user that I don't understand (see the table below
from my previous mail). We will try to overcome it in a way or another
... unless somebody has another idea about it !!!
J.F. Gournay
CEA Saclay
IRFU/SIS
De : Andrew Johnson [mailto:[email protected]]
Envoyé : mercredi 9 septembre 2009 16:56
À : [email protected]
Cc : GOURNAY Jean-Francois
On Wednesday 09 September 2009 07:34:52 GOURNAY Jean-Francois wrote:
> I did more systematic tests and I have this strange situation:
> ASGVAL UAG spiral2 spiral2mgr gournay
> 1 tous W W W OK
> 2 develop - - (should be W) - WRONG
> 4 physique W - - OK
> 8 gournay - W (should be -) W WRONG
> W : database WRITE access
> - : no write access
> I modified the CALC expressions accordingly to Martin suggestion :
> CALC("A&1") instead of CALC("A&1=1"). But I don't think I have to write
> CALC (A>0&&A<2) as my A value comes from a longout record.
You're right there, but for historical reasons the relative precedence of
the ">>" and "=" operators are different in C and CALC, so you do need to
change your expressions:
> CALC("A&1=1")
As Marty suggested "A&1" is sufficient here
> CALC("A>>1=1")
CALC actually evaluates this as "A>>(1=1)" which is not what you
mean. You
could use "(A>>1)=1" but I would suggest "A&2" here instead.
> CALC("A>>2=1")
"A&4"
> CALC("A>>3=1")
"A&8"
Using fewer operators will also parse and execute faster.
> This message sent yesterday didn't show up.
That's because you actually sent it to tech-talk-bounces@aps., not to
tech-talk@aps., and I didn't get a chance to forward it manually
before you
re-sent it.
HTH,
- Andrew
J.F. Gournay
CEA Saclay
IRFU/SIS
